How make a wall the loudest?
not every car works well with port behind driver
ive had VERY good luck with subs bottom port up top
and a 1500 per sub..lol...be wayyy careful if you have electrical to support them
what crap are you smoking in db drag subs pass side port driver side is the loudest spl period........
no matter the car
i wouldnt wast my time doing a wall with those subs but that me
he speaks the truth
R.I.P!
(Nov-29-2009)
92 explorer
current build
They wall fine, just not as well as others is all. Plus 1500 is a bit much for L7's.
Hammerdown... 1%
whats your budget?
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 1261 Guests (See full list)
