Mechman Alternators
need help guys wiring up my new mechmans
Our units have the GM plug out the back? If so, just match the wires on the plugs, and connect as I said above and it will work fine provided that they are set up from our shop for external regulator use.
Edited by MECHMAN
so you have mechman alts
someone elses harnesses.
Why not just ask mechman to price you a harness. I bet that would solve the aggravation of trying to patch something together. it may cost a little more but its probably better to know its goign to work.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Beautiful alts...that is the exact setup I want to change too.....
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
This may be the best solution unless pinning that plug properly gets things working. I don't understand why DC won't help you, but we will do what we can to get this straight for you.
and people say im a dick and not helpful. ha
  • Like (+1 Rep) 4
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 627 Guests (See full list)
