Chaosgrunt Posted May 13, 2012 Report Posted May 13, 2012 Well I used the cc-1 to gain match 2 channels on a 4 channel amplifier. There are 2 gain knobs on the amp. 1 for channel 1&2, and the other for 3&4. After using the cc-1 to gain match, one channel was at..... lets say 40 volts and the other that I was matching to was at 30. I can't remember the exact volts. I was using the 40 -5 DB track when doing this. Was I supposed to use another track or should I just use a volt meter to gain match? I Just trusted that the cc-1 was right and left it since its not a big deal if it was wrong. Any help is appreciated, thanks. Quote
Ray Posted May 13, 2012 Report Posted May 13, 2012 Are you using all 4 channels for subwoofers? What made you choose that track for the test? Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Chaosgrunt Posted May 13, 2012 Author Report Posted May 13, 2012 Yeah its for subwoofers. 1&2 are bridged and 3&4 are bridged. Its my friends setup lol. There is a lpf on there as well. Quote
Ray Posted May 13, 2012 Report Posted May 13, 2012 Did you match voltage with the amp filter on full pass or lpf? Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Ray Posted May 13, 2012 Report Posted May 13, 2012 Re read the manual. Then do it how the manual says. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Chaosgrunt Posted May 13, 2012 Author Report Posted May 13, 2012 Idk where the manual is but I think d amore has it on their site. Ill check and see if I did it right then ill post again. Quote
Chaosgrunt Posted May 13, 2012 Author Report Posted May 13, 2012 Well, after reading it I did everything it said except I played it at 40 -5 DB which shouldn't really matter. Ill do it again at 40hz but I'm sure the results will be the same. Quote
Chaosgrunt Posted May 13, 2012 Author Report Posted May 13, 2012 After all, it matches output. As long as both channels read the same signal, it should still match it. Quote
