BrandonT94 Posted May 15, 2012 Report Share Posted May 15, 2012 (edited) I just got on trade an older Majestic 60 watt 4 channel amp. The ground is bad on it but it comes on then back of. The amp does not have the screws for the power ground and remote like newer ones it just has an opening that has the wires coming out from them. Can this be fixed? Am I even correct that the ground is bad? Edited May 15, 2012 by BrandonT94 Quote Link to comment Share on other sites More sharing options...
bobobass Posted May 15, 2012 Report Share Posted May 15, 2012 Any pics of this amp? Quote 2000 Subaru outback 2.5l Head Unit: Pioneer deh 4300ub front stage: tbd subwoofer: Stock Fi Q 18" amp: Audio que 1200d Link to comment Share on other sites More sharing options...
BrandonT94 Posted May 15, 2012 Author Report Share Posted May 15, 2012 not at the moment i will as soon as i can though Quote Link to comment Share on other sites More sharing options...
BrandonT94 Posted May 15, 2012 Author Report Share Posted May 15, 2012 http://imgur.com/a/Gdz9Q#vKeDl Quote Link to comment Share on other sites More sharing options...
95legwagon Posted May 15, 2012 Report Share Posted May 15, 2012 that ground should be fixed for sure....looks pretty narly bro Quote i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq Link to comment Share on other sites More sharing options...
RooTxBeeR Posted May 15, 2012 Report Share Posted May 15, 2012 (edited) Edit: Re looked over, yeah you should redo that ground. Edited May 15, 2012 by RooTxBeeR Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
Kranny Posted May 15, 2012 Report Share Posted May 15, 2012 x-whatever on redoing that ground. do it properly though, not like the previous owner did. thats a shit solder job to be honest. get a soldering vacuum plunger or however you'd like to remove as much solder from that spot as possible, clean up the hole really well with rubbing alcohol, stick new wire in, solder to board. you should be good to go then. Quote Link to comment Share on other sites More sharing options...
BrandonT94 Posted May 15, 2012 Author Report Share Posted May 15, 2012 (edited) ok but how exactly do should I do it? edit: ok should the solder be in line with the silver like it is now? or does it matter? Edited May 15, 2012 by BrandonT94 Quote Link to comment Share on other sites More sharing options...
Kranny Posted May 15, 2012 Report Share Posted May 15, 2012 well the wire should be going through a hole in the board for it to pass through, and get soldered. i dont really understand what you mean by it being in line with the silver trace thats there now. just put the wire in and solder it. thats a really fucked up solder job right there, so try not to duplicate that lol Quote Link to comment Share on other sites More sharing options...
tacomabanga1986 Posted May 15, 2012 Report Share Posted May 15, 2012 never seen the 4 channel ones, i got a 2ch majestic amp does ok for a 90's amp i think, not alot of power tho Quote here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit Link to comment Share on other sites More sharing options...
