if you fed those kickers 1500RMS you would fry them quick. They are ment to take 800RMS as a pair. As long as you design the box right, you should be able to put 1k to them without hurting them, but 1500 is a bit much.
woman..cant live with em...cant shoot em...guess were all fucked
You might be a Redneck if you use your leftover gutters for a speaker box port...
YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
Which model, which VCs...cuz you say 1 ohm, is that dual 2s wired to 1 ohm each, or dual 4s wired to 2 ohms each, then parallel to 1 ohm final load?
Personally, i wouldn't do that to them...you can buy a 1200w amp and leave the gain turned down, headroom is always a good thing to have. I personally am not a huge kicker fan...Ive had a set of clarion PXW1251s for about 4-5 years now, rated for 500wRMS a piece. Currently I'm feeding them around 600 a piece. To be honest, if they blow they blow, they are 5 years old, one has a hold in the surround that i sealed with silicone 1 hour before a comp back when i had my blazer (hit a 141 at 37Hz on music that day). If and when they blow, I'm going with a single 15, dual 2, that can handle 1700wRMS daily.
Again, i would advise against pushing them 50% past rated power....thats ballsy...
Give them a good clean 800w RMS and be happy (1kw RMS MAX!!!! i wouldn't feed these more than 500RMS each if were you, and even then, id stick closer to the 400, if you want to run 1200w, buy new subs), build a large ported box to get the most out of them....when i had my blazer, my box was ~4.2cuft i think, tuned around 32Hz, with ~16 in of port per cube.... Current box is ~3.8 net, 14.5 in/cube, 34Hz, but its in a trunk...it doesn't hit nearly as hard as my blazer did, but it still hits....
Edited by siucsaluki11
  • Who's Online   0 Members, 0 Anonymous, 489 Guests (See full list)
