I have a older alpine 9811 and I tuned my system with the dd1 and it sounds great but I was thinking I used the cd to tune everything but when I listen to music I never use the cd player its all on my ipod so should I put the tracks on my ipod and set it that way or am I fine where I'm at
I do the same thing you do. I put them on my iPod and set gains with that. Turn the eq off and make sure your iPod doesn't clip too
  • 3 weeks later...
Treat your ipod as just another source. I'm not sure if it has a strong enough signal to drive the internals of the dd-1.
Plug it into your deck, turn up the volume half way, turn up your iPod all the way, and test with tracks 1&2. If it clips, turn down the volume until it doesn't clip and there should be some sort of volume lock in the settings so you can't turn it up past that point.
Then set everything else like normal
Steve meade a vid reguarding this awhile back
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
  • 3 months later...
the ipod via 3.5mm is weak
but if you use the ipod dock port with a cable to the head unit, it seems just as good as USB/CD/DVD
2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz
guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
  • 7 years later...
  • Who's Online   0 Members, 0 Anonymous, 1627 Guests (See full list)
