James365 Posted January 17, 2014 Report Share Posted January 17, 2014 I have 2 sa8V2 running Rockford Fosgate 1000.1 bdcp. running 1 ohm. no issues, and pushes massive air for two 8" subs. ( I say massive, simply because I can do a hair trick with my setup in the trunk of a BMW through a ski port... without the trunk being sealed off.... seems massive to me LOL) Quote Link to comment Share on other sites More sharing options...
n8ball2013 Posted January 17, 2014 Report Share Posted January 17, 2014 I would love to see a 2 8 hair trick Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
James365 Posted January 17, 2014 Report Share Posted January 17, 2014 I would love to see a 2 8 hair trick don't get me wrong.. it's nothing like most of the hair tricks on here.... Mind you they are two 8 inch subs.. but playing decaf off of my phone. I cannot make a video while connect.. When my wife gets home next week. (she has my camera) I will take a video for you failed attempt of a hair trick or not. I will try and post a video. Quote Link to comment Share on other sites More sharing options...
Neckbeard Posted January 17, 2014 Report Share Posted January 17, 2014 Ive got an NS-1 to 2 of them. this box they are in is about .6 per woofer with a 4" aero, I just rebuilt a box to 1cube per woofer with 40sq" of port and it only takes that power around tuning, but under tuning i have to turn the HU down a couple clicks. I'm impressed with the little guys! 1 Quote Build log, Super slow!!: http://www.stevemeadedesigns.com/board/topic/168096-slow-neckbeards-1970-opel-gt/ Link to comment Share on other sites More sharing options...
SICKSPD Posted January 18, 2014 Report Share Posted January 18, 2014 im running 3 SA-8 V2's to a monoblock 5000 watt boss amp, turned amp down and clamped power output, running approx. 1500 watts to each wired down to 1 ohm, they handle it well, they are in a 3.2 cu/ft box ported at 34 htz. if you run a ported box make your port plenty big, these move A LOT of air lulz...boss amp. I bet them 8's are handling that 5kw very well. Quote 09 Challenger R/T (Audio system under construction): Pioneer AVH-X4500BT (PAC RP4CH11 harness) (2) Sundown Audio SA-8v2 (inverted) CT Sounds AT1400.1D XS Power D3400 40 sq ft. Audiotechnix deadener 1/0 Audiotechnix wiring stock Boston Acoustic 7 speaker amplified system (for now) Sealed trunk enclosure Build log: http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/ TEAM GOAT Link to comment Share on other sites More sharing options...
