What Amp do I need to run 4 SA-8 v2's?
we say a 3k, because after voltage drop and impedance rise, you'll see about 2k, also...sundown subs are underrated, and will take around 700-800. judging by all these posts i've read, seems like you shouldn't be hooking anything up by yourself what so ever, and you should not cheap out on an amp. if you're going to spend that much money on brand new 8's, you might as well get the decent electrical, and amp to power them. if not, go to nearest walmart. and i heard that sony xplod subs are pretty cheap, along with their sony xplod amp. good luck, edit...the brz series of amps isnt that bad, actually. i've heard alot of people complain about blowing them up, you could always look into a crescendo bc2k
Edited by cjN
2x sundown audio sa 12's
Crescendo BC2000
kinetik 1800, 1400.
Rockford punch 5,25 component set
MB QUART ONYX 4.80
Mechman 270a alt
Well I wanted a cheaper amp because I don't want to spend a lot of money if I don't need to, also I live in the UK and we don't have a Walmart. So im basically going to pay about £1200 just on the subs and a amp? And if a amp says it gives 700 Watts at 4 ohms what does that mean?
it means it gives 700 watts when wired to 4 ohms....and yes, you're probably going to pay alot for subs and an amp, this hobby isn't cheap, lol, you could always run 2 12's and a 2k amp.
Crescendo BC2000
kinetik 1800, 1400.
MB QUART ONYX 4.80
Mechman 270a alt
crescendo
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
dont worry your not the only one dropping big cash to get them i was just under 700au for 2, on that price youll be £700 just on subs alone,
if you want a cheaper amp and less up grading on the elec, just get a 1-1500k amp and when you have more cash upgrade elec and get a bigger amp,
what ohm subs did you get?
as this will affect what amp you get also,
but idd drop at-least 2600-3200rms on them.
SA 8 v.2 D2
RE: 3.36 ohms
FS: 34.6 Hz
VAS: 7.44 L
Qes: 0.35
Qms: 10.10
Qts: 0.33
Le: 1.34 mH
BL: 17.56 NA
Mms: 146.120 g
Sens: 81.5
RMS: 500 Watts
Edited by Cazz
  • Who's Online   0 Members, 0 Anonymous, 1269 Guests (See full list)
