southern66ss Posted July 4, 2012 Report Share Posted July 4, 2012 I'm getting ready to start the new build and was wanting to check out a few things first. Would 2 LVL4m2 12's be able to handle the 3.5K on them at 1 ohm or do i need to stay with the 2.0K? Also i know the site says 1.5f3 on the ported for the lvl4 12's but what do y'all recommend? Quote 2001 Toyota Avalon (stock other than system)2009 Mitsubishi Lancer GTS (Cat-back custom Exhaust w/ Magnaflow muffler, ECU Flash)1966 Chevelle SS (402BBC, Built TH350 w/2500 stall, Flowmaster exhaust, Coy 5 Spoke Rims, Holley Carb, Elderbrock Intake, Comp Cams Valve Train)Current in Avalon:Kenwood DNX5180 HUJBL 6.5" in front doorsJBL 3/4" tweets in dashJBL 3.5" rear doorsJBL 200w 4ch amp RE Audio SEX 12D4 Subs (12") Hifonics Brutus BRZ1200.1D NVX 4 gauge wiring NVX Deadner XS Power D925 Big 3 1/0 ga Q Power wire Custom box by Pro Audio Gulfport, MS 137.5 SB2 USACIhttp://www.stevemead...on-xls-build-up Link to comment Share on other sites More sharing options...
CJ18 Posted July 4, 2012 Report Share Posted July 4, 2012 You will be perfectly fine with the Level 4s on 1 3.5k at 1 ohm. 1.5ft3 per sub net is recommended. Please send me a PM if you have any questions or need pricing on the equipment. Quote Link to comment Share on other sites More sharing options...
southern66ss Posted July 4, 2012 Author Report Share Posted July 4, 2012 Thanks CJ, will do bro. Quote 2001 Toyota Avalon (stock other than system)2009 Mitsubishi Lancer GTS (Cat-back custom Exhaust w/ Magnaflow muffler, ECU Flash)1966 Chevelle SS (402BBC, Built TH350 w/2500 stall, Flowmaster exhaust, Coy 5 Spoke Rims, Holley Carb, Elderbrock Intake, Comp Cams Valve Train)Current in Avalon:Kenwood DNX5180 HUJBL 6.5" in front doorsJBL 3/4" tweets in dashJBL 3.5" rear doorsJBL 200w 4ch amp RE Audio SEX 12D4 Subs (12") Hifonics Brutus BRZ1200.1D NVX 4 gauge wiring NVX Deadner XS Power D925 Big 3 1/0 ga Q Power wire Custom box by Pro Audio Gulfport, MS 137.5 SB2 USACIhttp://www.stevemead...on-xls-build-up Link to comment Share on other sites More sharing options...
OG BudBone Posted July 4, 2012 Report Share Posted July 4, 2012 It'll be perfect, that's my daily setup up Quote 1997 Trans Am WS6 Pioneer DEH-P5200HD 2 DC Level 4 M2 12s 4 cubes tuned to about 34hz DC 3.5k 1/0 Welding Supply Ultra Flex Stock 140A alt Stinger Fuses & Fuse Holders XS Power D5100 XS Power XP3000 Link to comment Share on other sites More sharing options...
southern66ss Posted July 4, 2012 Author Report Share Posted July 4, 2012 bwolf, i'm just wondering how much i can expect out of this combo when it is a trunk with a seat that can't fold down. I only have a ski hole to port through into the cabin. Quote 2001 Toyota Avalon (stock other than system)2009 Mitsubishi Lancer GTS (Cat-back custom Exhaust w/ Magnaflow muffler, ECU Flash)1966 Chevelle SS (402BBC, Built TH350 w/2500 stall, Flowmaster exhaust, Coy 5 Spoke Rims, Holley Carb, Elderbrock Intake, Comp Cams Valve Train)Current in Avalon:Kenwood DNX5180 HUJBL 6.5" in front doorsJBL 3/4" tweets in dashJBL 3.5" rear doorsJBL 200w 4ch amp RE Audio SEX 12D4 Subs (12") Hifonics Brutus BRZ1200.1D NVX 4 gauge wiring NVX Deadner XS Power D925 Big 3 1/0 ga Q Power wire Custom box by Pro Audio Gulfport, MS 137.5 SB2 USACIhttp://www.stevemead...on-xls-build-up Link to comment Share on other sites More sharing options...
Slapuhho Posted July 4, 2012 Report Share Posted July 4, 2012 Of course! Might as well get level 2's.. DC subs can take any amount of power! Quote 4 18's, low power and lots of gay fur. Team gg Team DOA My Videos Link to comment Share on other sites More sharing options...
OG BudBone Posted July 4, 2012 Report Share Posted July 4, 2012 Well I'm sure it would sound good, too many variables to be exact, build a good box i bet it'll get nice and loud. Mines currently in a trans am hatch, sealed box but it still pounds like a champ, no problems Quote 1997 Trans Am WS6 Pioneer DEH-P5200HD 2 DC Level 4 M2 12s 4 cubes tuned to about 34hz DC 3.5k 1/0 Welding Supply Ultra Flex Stock 140A alt Stinger Fuses & Fuse Holders XS Power D5100 XS Power XP3000 Link to comment Share on other sites More sharing options...
vetkilr01 Posted July 4, 2012 Report Share Posted July 4, 2012 I should be able to answer this by the end of the day Quote Link to comment Share on other sites More sharing options...
doodcody Posted July 4, 2012 Report Share Posted July 4, 2012 I should be able to answer this by the end of the day I really like what your doing with my old subs:) Quote Link to comment Share on other sites More sharing options...
Joshua Boehler Posted July 4, 2012 Report Share Posted July 4, 2012 I HAVE 6 15 KICKER COMP VR DVC 2OHM AND ONE OF THEM WILL JUST STOP WORKING LIKE THE COIL IS STUCK BUT I'LL PUSH IN ON IT THERE'S NO CRUNCHING AND IT WILL WORK LIKE NO PROBLEM, WHAT IS WRONG AND HOW TO FIX THANKS Quote Link to comment Share on other sites More sharing options...
