DC Sound Lab
DC Audio t/s parameters
what exactly do the t/s parameters mean?
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
Source: http://svconline.com/proav/coil_understanding-thiele-small-parameters/
Understanding Thiele-Small Parameters
The Thiele-Small (T-S) parameters are commonly used by engineers to define the relationship between a speaker and a particular enclosure. But they can also provide some measures describing loudspeaker components that defy marketing interpretation.
The Thiele-Small (T-S) parameters are commonly used by engineers to define the relationship between a speaker and a particular enclosure. But they can also provide some measures describing loudspeaker components that defy marketing interpretation. Here are some of the more useful T-S parameters and what they mean:
Fs: The free-air resonant frequency of a speaker. In general, a lower Fs indicates a woofer that would be better for low-frequency reproduction than a woofer with a higher Fs.
Re: The DC resistance of the driver measured with an ohm meter. This measurement will almost always be less than the driver's nominal impedance.
Le: The voice coil inductance measured in millihenries (mH). The industry standard is to measure inductance at 1kHz. As frequencies get higher there will be a rise in impedance above Re because the voice coil is acting as an inductor. Thus, the impedance of a speaker is not a fixed resistance, but changes as the input frequency changes. Maximum impedance (Zmax) occurs at Fs.
Q parameters: Measurements related to the control of a transducer's suspension when it reaches the resonant frequency (Fs). The suspension must prevent any lateral motion that might allow the voice coil and pole to touch (damaging the loudspeaker). Qms is a measurement of the control from the speaker's mechanical suspension system (the surround and spider). Qes is a measurement of the control from the speaker's electrical suspension system (the voice coil and magnet). Qts is the “Total Q” of the driver. In general, Qts of 0.4 or below indicates a transducer well-suited to a vented enclosure. Qts between 0.4 and 0.7 indicates suitability for a sealed enclosure. Qts of 0.7 or above indicates suitability for free-air or infinite baffle applications.
Cms: The “compliance” of the suspension in a particular speaker. Cms is a measurement of its stiffness measured in meters per Newton.
Vd: The Peak Diaphragm Displacement Volume, or the volume of air the cone will move. It is calculated by multiplying Xmax (voice coil overhang of the driver) by Sd (surface area of the cone). Vd is noted in cc. The highest Vd figure is desirable for a sub-bass transducer.
BL: Expressed in Tesla meters, this is a measurement of the motor strength of a speaker. Think of this as how good a weightlifter the transducer is. The formula is mass in grams divided by the current in amperes. A high BL figure indicates a very strong transducer that moves the cone with authority.
Mms: The combination of the weight of the cone assembly plus the “driver radiation mass load.” The weight of the cone assembly is easy: it's just the sum of the weight of the cone assembly components. The driver radiation mass load is the weight of the air (the amount calculated in Vd) that the cone will have to push.
Xmax/Xlim: Short for Maximum Linear Excursion. Speaker output becomes nonlinear when the voice coil begins to leave the magnetic gap. Although suspensions can create nonlinearity in output, the point at which the number of turns in the gap (see BL) begins to decrease is when distortion starts to increase.
Sd: This is the actual surface area of the cone, normally given in square cm.
  • Like (+1 Rep) 4
sweet thanks man!
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
Team DC Audio
Was expecting the Fs of the level 6 to be higher than that.... nice :drink40:
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
Thanks for posting this cj..
Got a question tho if a spec for xmas says 26mm@60%bl what exactly r they trying to say?
2x dcaudio lvl4xl 15's
1x dc power 270xp alt
2x rockford 2500 1bd
2x big3 2x front to back 0.gage jl
1x optima yellow top under the hood
1x xs power d3100
2x xs power 925
148.6 db sealed to music 149.5 db sealed 42hz term lab
  • Who's Online   0 Members, 0 Anonymous, 1209 Guests (See full list)
