Ground to the Chassis or Run a Ground Cable? CE Auto Electric Supply Partners with D'Amore Engineering to answer - Video on Pg 5!
Now what if both connections were perfect?
Still think cable can carry the current better?
Would a frame car be a closer match to the cable?
Great answers so far.
Cant wait to see the video.
from what ive learned on SMD.. to answer those questions.. its..
1.) if both connections were perfect, copper still carries current better than steel. so the 1/0 would win there
2.) a direct shot with a superior conductor would carry the current "better"
3.) frame to car would be close, but the OFC copper should still win. now by how big of a margin? i'm not sure.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
As for a unibody, i thought you ground to the thickest part oh metal, and almost every unibody has a sub frame such as where the engine is, or just run your own ground from the battery back. Dunno really lol.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
what about thickness of the frame...
Edited by ChevyBoy95
Humm. Interesting.
So, regaurdless of surface area, ofc is better because it conducts better than steel..
Humm. Interesting.
i have NO idea honestly about that. but i personally rather run straight grounds off the batt/alt right to the amp.
and if im not mistaken, you do the same. (not entirely sure on that, i dont keep up with your builds really)
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
Yeah... Lets talk about unibody vs. running a ground front to back.
Sheet metal vsa 1/0 cable
Or does it even matter cause you're using a cable from the amp anyway?
The way I do it depends on where my battery bank is.
Honestly i overkill it.
 Share
