Sign in to follow this
snafu
Ground to the Chassis or Run a Ground Cable? CE Auto Electric Supply Partners with D'Amore Engineering to answer - Video on Pg 5!
I think he was referring to a single run of each, I think anyway.
F-150, Sundown Audio & Rockford Fosgate build
My someone what uniterrupted build log (xD UBL)
My xD build in it's current form. (SOLD)
My old builds!
My YouTube channel
My Garage link
Current Equipment:
Pioneer App Radio 3
RF T1652-s components
(2) Sundown Audio SA-8v2
RF 3sixty.2
RF T400.4
RF T1500.1 bdcp
Sky High Car Audio power, ground, and speaker wiring
Share this post
Link to post
I hardly ever run ground also.
Maybe on 2-3 of the big systems ive done.
Even then it was only like 1-2 1/0's for ground reference
Actually tying to find the grounding system i like.. Ill post once i find it.
Share this post
Link to post
..............asked
Well, he ^ "Do I need to run the same size ground lead from my battery to the rear of the vehicle as my power lead? IE - If I run a 1/0 AWG power wire, should I also run a 1/0 AWG ground wire?"
So, no. Think about it. Even having one battery up front and 5 in back, One terminal wont support 5. Maybe multiple grounds from engine block to back would help, but not from battery.
edited
Edited by strangeduck
Share this post
Link to post
That looks pretty cool Ray!
My old builds!
My YouTube channel
My Garage link
Current Equipment:
Pioneer App Radio 3
RF 3sixty.2
RF T400.4
RF T1500.1 bdcp
Share this post
Link to post
Well, he "Do I need to run the same size ground lead from my battery to the rear of the vehicle as my power lead? IE - If I run a 1/0 AWG power wire, should I also run a 1/0 AWG ground wire?"
Maybe I understood it wrong :) I thought he meant if a single 1/0AWG power wire is enough on the positive side, is it better to use a chassis ground or a second 1/0AWG power wire on the negative side.
My old builds!
My YouTube channel
My Garage link
Current Equipment:
Pioneer App Radio 3
RF 3sixty.2
RF T400.4
RF T1500.1 bdcp
Share this post
Link to post
I think you understood it, i'm just using an extreme to prove a point. All I am saying is if you do it, do it from engine ground, not battery.
Share this post
Link to post
I have been using that kit for all my amp grounds since 2005. Bought it from Select Products back in the day. Love that kit.
2006 Chevy Cobalt SS
Headunit: Eclipse 8445 (sold)
Highs Amp: Eclipse 3620 (sold)
Sub Amp: Eclipse 3122 (sold)
Front stage: Memphis M class6.5 components (2007)
Sub: 1 Memphis M class 12" (sold)
SPL TermLab 130.7 (windshield) (selling)
Car Audio & Alarm installer for 16 years.
Pray for my daughter Katrina please!
Share this post
Link to post
PPi back in the 90's used to run grounds back to the battery but the rocket scientists always said the cable presented its own resistance over the length.
Then we have the others that want the same gauge, and our all about the chassis ground, however today's vehicles with the spot welds, vehicle frame/unibody dipped in corrosion protection and acid baths... also present its own problems with resistance
You also have to look at how the battery is grounded also (and alternator supply wire)
I personally like the same gauge, and grounding to the frame when I cant ground to the battery :) either way the amp turns on and produces music... hell some are even going strong for over 15 years now in the same car :)
SMD SuperSeller VerifiedJbondoXJames Shields
Share this post
Link to post
