Basically, I really would like some ideas on the best painting method to get a finish with heavy texture like all pro audio subwoofer enclosures. I need a finish that can take a beating from being moved around & such. Thanks!
B.T.T.M
-Jake Ryan
  • Replies 22
  • Created
  • Last Reply
Rhinoliner is best bet..or use resin the texture paint after words
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
bedliner can take a beating. it doesn't look too bad and has a grippy texture too
^Bedliner is probably your best bet if you want paint that isn't easy to scuff. Either that or use a textured spray paint like a stone texture.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
How much would someone say it would cost to cover a box with rhinoliner? like a 4-5cu gross enclosure.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I could honestly not know about rhinoliner but bedliner is like 30 or something dollars a can.
B.T.T.M
-Jake Ryan
Sand it with ~40 grit sandpaper and paint with 2 coats of herculiner/rhinoliner/etc (not the shitty duplicolor spray stuff) using a sponge roller.
That's what I do and it comes out tough as nails
  • Who's Online   1 Member, 0 Anonymous, 255 Guests (See full list)
