Mechman Alternators
so a few of us honda guys got to talkin in pm and in our little thread about when our belts would start slipping.
basically what we want to know is since DC power makes a 270 amp alt for our vehicle and no one else on the market even comes close.. would our belts slip on their 250 amp and 270 amp units?
if no load is applied at idle then the load is applied at 2-3k rpm would we still get belt slip?
if we rolled into the volume knob would the belt slip not be a factor?
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
correct belt wrap is the key. All of us chevy guys with multi alts get slippage
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
You should be fine tho. when I had a 270 on my Toyota 2.2l I had belt slip, then I tightened up the alt correctly and I never had a problem after.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Can you define belt wrap for me?
I just want a full answer and not have any more questions about belt slip lol.
Basically just make sure it has the proper tension on it?
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
But doesn't the slippage hinder the output amperage of the alt. So wouldn't having a lot of slip defeat the purpose of having an the 270 over say some of the smaller ones
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
yes this was the question raised in our discussion.
with the proper tension on the belt, would a 270 amp alt be too hard for a 650 rpm 1.8L engine to turn properly?
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
I have a triple DC Power alt setup on my Avalanche and have never had belt slip. I don't think it has anything to do with which company you use but like everyone is saying the belt wrap.
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
Ehhh you would be pushing it on a 1.8 but I think it has been done successfully.
under construction
u hate c-fizzy?
define belt wrap.
I believe belt wrap is the percentage of the pully the the belt actually comes in contact with. This contact introduces friction. Less area with pully/belt contact = less friction = gretaer chance of belt slip. More area with pully/belt contact = more friction = lesser chance of belt slip.
The above assumes a properly fit belt and a good working tensioner if applicable.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   1 Member, 0 Anonymous, 191 Guests (See full list)
