Street Stock Questions
bench
As of 2012:
The rule is amps rated at no more then 2000w. Long as the rms stated by manufacture is not over 2000 watts your fine.
Any rating above 2000w at any voltage or ohm level by the manufacture would deem the amp in violation of rule.
no we are not clamping going by mfg specs
you both should read this then http://audioforum.te...ad.php?t=150887
i have read that
we watch the list of amps that are deemed illigal after being clampped but sorry unless wayne or you buy us a clamp meter it is not a requerment for us to do so
and yes if it has a listed rating of 2400 watts at 16 volts even if your not using 16 volts its no good
remeber this is a class for for the small wallet or new compitors that have not done the whole go big or go home mind set yet
ok well I'm going to leave this alone. there is already a thread on termpro
where is this "list" you talk about?
Would i qualify for stock? If so, i'll be looking for an amp for next yr. =)
good luck finding the right amp.oh and if you look now i have a feeling the rule will change next year. you will kick yourself in the rear for not buying something else.
wouldnt that be a bum'r.... Dam depressing
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
yes it is a bummer. I was wanting to hit the lake county show in this class but dont want to buy an amp. if they change the rules it just means a better amp can be had
