revoracing247 Posted October 3, 2012 Report Share Posted October 3, 2012 hey guys, i have a friend who has a Kicker ZX650.4 amp and in one of the channels it just started giving out a lot of static. or like white noise. it gives off the static even when the car is off, and it's like a steady tone, so it's not like an alt whine or engine noise from a bad ground. the amp is like 6 years old. anyways if anyone has any ideas or anything it's be a big help!! thanks! I think you have a bit of truck stuck in your mud bro ~Ford Ranger, ext cabKenwood DDX4701/0ga stinger wiring for big 31/0ga ofc flextech wiring 3 kinetik 800's AQ2200 @1ohm Sundown Audio X15 in a 27Hz tuned ported box LE BUILD LOG!!! Link to comment Share on other sites More sharing options...
revoracing247 Posted October 3, 2012 Author Report Share Posted October 3, 2012 any ideas? i heard i could maybe be from old drying up caps. anyone to back that up? I think you have a bit of truck stuck in your mud bro ~Ford Ranger, ext cabKenwood DDX4701/0ga stinger wiring for big 31/0ga ofc flextech wiring 3 kinetik 800's AQ2200 @1ohm Sundown Audio X15 in a 27Hz tuned ported box LE BUILD LOG!!! Link to comment Share on other sites More sharing options...
Skullz Posted October 3, 2012 Report Share Posted October 3, 2012 Don't sound good, i would send it in and have it looked at cause it may need to be repaired providing your still wanting to use it. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
revoracing247 Posted October 3, 2012 Author Report Share Posted October 3, 2012 yeah i he still want's to use it, i was just wondering if it was maybe something i could do myself cause i do have pretty much all the electronics tools i'd need at me disposal and i really wanna learn more about amps and what not. I think you have a bit of truck stuck in your mud bro ~Ford Ranger, ext cabKenwood DDX4701/0ga stinger wiring for big 31/0ga ofc flextech wiring 3 kinetik 800's AQ2200 @1ohm Sundown Audio X15 in a 27Hz tuned ported box LE BUILD LOG!!! Link to comment Share on other sites More sharing options...
Pioneerchuck Posted October 4, 2012 Report Share Posted October 4, 2012 If it sounds like interferance it could be a bad ground. Sometimes Ive seen on cars where the amp is grounded to the body i.e. a seat belt bolt, floor, or bare metal body surface, instead of a direct ground to the battery can cause the white noise or interferencce sound. Link to comment Share on other sites More sharing options...
