FrontierGello Posted October 22, 2012 Report Share Posted October 22, 2012 How do you remove a heated sound deadener that has sticked at a metal surface? Quote Nissan Frontier 10" Cadence Midbass 8" Cadnece Midrange Bullet tweets 2 Re audio Sxx 15 Subs Mechman 270a 2 Re XT4000deV3 mono 1600 rms 1 Re XT400deV3 Bridged 350x2 2 Cadence 175.4 Bridged 350x2 Audiomaxx and Stinger 0,4,8,12 awg wires Dynamat sound deadeners My Build Log: http://www.stevemead...__+1999 +nissan Link to comment Share on other sites More sharing options...
emperorjj1 Posted October 22, 2012 Report Share Posted October 22, 2012 heated sound deadener? Quote J. JMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer Link to comment Share on other sites More sharing options...
reg93f150 Posted October 22, 2012 Report Share Posted October 22, 2012 (edited) you can try dry ice or an aresol can of freeze spray and a chisel to just pop it off, it will get harder when its like frozen cold i believe and easier to pop off without all the goo stuck on there Edited October 22, 2012 by reg93f150 Quote ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub Link to comment Share on other sites More sharing options...
suckerfreebass Posted October 22, 2012 Report Share Posted October 22, 2012 try an pull what you can off maybe heat it up an peel also use razor blade to clean surface Quote Link to comment Share on other sites More sharing options...
n8ball2013 Posted October 22, 2012 Report Share Posted October 22, 2012 id use channel locks and pull like hell. have fun if its a good deadener you are going to have your hands full. and watch the foil it will tear you up with a quickness. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Second Skin Rep Jon Posted October 22, 2012 Report Share Posted October 22, 2012 Factory installed sound deadener that is applied with heat (and typically lacks a foil top layer) can be removed chemically (not recommended) or by use of more heat OR extreme cold from dry ice as mentioned above. Either way you go at it, it's a mess and is time consuming. If it's aftermarket sound deadener like Damplifier or Dynamat, as N8 suggested... pull like hell! And I've found that if you pull on the material parallel with the surface it's applied to (vs. just pulling straight up on it), it comes off a little bit easier. Quote Have a question about Second Skin? E-Mail me! Link to comment Share on other sites More sharing options...
FrontierGello Posted October 23, 2012 Author Report Share Posted October 23, 2012 Ok. Thanks guys Quote Nissan Frontier 10" Cadence Midbass 8" Cadnece Midrange Bullet tweets 2 Re audio Sxx 15 Subs Mechman 270a 2 Re XT4000deV3 mono 1600 rms 1 Re XT400deV3 Bridged 350x2 2 Cadence 175.4 Bridged 350x2 Audiomaxx and Stinger 0,4,8,12 awg wires Dynamat sound deadeners My Build Log: http://www.stevemead...__+1999 +nissan Link to comment Share on other sites More sharing options...
