My Lexus ISF Sound System Diagram
I rarely see the SMD being ran at 3500w! I have a SAZ3500 @ .35 and it sounds GREAT all the way up! But it does want more power! I am getting a DDz2 on it and wire it up to 1.4 to be safe! It should be under 7k with rise! But a .35 burp will be tempting! What's the most you've put on one?!?!
my SMD is not on 3500w. There is 2 T2500.1bd on it.....look at the diagram :D
  • Like (+1 Rep) 3
Follow my Tweet (Twitter)
Looks great didn't notice you had that much in there, would like to hear it one day.
Edited by tdsa23
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
my SMD is not on 3500w. There is 2 T2500.1bd on it.....look at the diagram biggrin.gif
more like 5-6kw, maybe more depending on rise and what he is listening to.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
can you post up the rca configurations...As far as them going into the amps from the 3sixty.3 and which speakers are where in the car... im curious as i have a similar setup with multiple amps mids and highs and looking into purchasing a 3sixty.3... thanks ahead of time...
Do you use the i-pad for all the tuning and the i-phone for the music storage?
nope. The Iphone is bluetoothing directly to the factory deck (I can use USB also) and i use that for music and hands free phone. The Ipad Bluetooth's directly to the 3sixty.3 as its own source. The 3sixty.3 also has optical and aux inputs which aren't used, yet.
I use my laptop for tuning via USB to the 3sixty.3.
Does the 3sixty.3 support higher resolution audio like 24bit/96khz on the optical? I can imagine a setup like yours could take real advantage of the extra detail in the music. I have a few albums in high res and even on the Yamahas in my office the difference is amazing.
2007 Pacifica
  • 3 months later...
Whole System came out beautiful.. I bet this one sounds clean as hell with those midrange Drivers.
Just not sure about the Battery capacity. Do you run .7 Coils or 1.4 on each amp ? had a similar setup and was missing power when i had 2 t2500's on .7 each with 3 d3100's and a mechman 270 xp alt.
Great setup.. !
thanks!!
right now, the sub is a D2. Its a "Constant power" amp so it is still doing good.
that being said, when i get my NEW SMD 15, it will be a D .7 or "D1". (Same thing)
so is your sub wired to 1 ohm???
  • Who's Online   2 Members, 0 Anonymous, 1667 Guests (See full list)
