Voltage questions !!
I have two sa12s on a saz1500 but I only have an xs d1200 in my trunk everything stock under the hood! My system dosen't seem very loud to me but my voltage commonly drops to 11.5, if I have a higher voltage like 13.5 on full tilt will my subs be louder. So my main question is does low voltage effect the output of watts on a amp?
Watts = P
Amps = I
Volts = V
P = I * V
If V is lower then P is lower and your output is lower.
Step 1 - do Big 3.
How big is the power wire from your front battery to the one in the rear?
What are you using to measure voltage drop and what part of your electrical system are you testing from?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
And I have a stinger voltage meter hooked up to the positives and negatives on my d1200 in the trunk and into the remote on my amp!
I'd replace that run of 4g with 0g all around. Including doing the big 3, that should help a bit. Also, make sure you have a good, solid and clean connection where your grounds are. You may want to look into a HO alt sometime down the road.
1991 Nissan Pathfinder
Mechman 240A alt
All wire 100% OFC 1/0
Kenwood KDC-X497
Pair of Kenwood Tweets/Pair of Rockford P1 5x7s
9ft3 vented box ~32hz
2 AQ HDC3 copper coil 18s
SAZ-3500 @ 1ohm
Powerbass ASA 200.2
39 sq. ft. damp pro.
Kinetik 1200&2400(x2)
What's the best thing for me to do for the cheapest? 0gage , another trunk battery , a under the hood battery, or the big 3?
Yes, the better you're electrical is the better the amp can perform. As for the cheapest to do at this point, upgrading from 4ga to 0ga is probably the cheapest route as of right now. You should be able to do that for somewhere in between $100- $200 depending on brand bought and amount. And is your under the hood battery stock or aftermarket?
  • Who's Online   1 Member, 0 Anonymous, 1568 Guests (See full list)
