What are you running on stock alternator?
I am curious to what the most draw on the stock alternator that there has been. Trying to decide if I can get away with just upgrading batteries for now, and get a H/O alternator down the road. Plus I think it would be cool to see what the biggest system on stock alternator has been.
Try to include:
Amps put out by the stock alternator
The batteries used
What amplifiers
Voltage drop while going full tilt
If the big 3 (4,5 etc) has been done
If there has been multiple runs of 1/0
Any other information that would that would be beneficial to know would be great.
Im going to contribute, but do not have all of the data your asking for.
Stock alternator : 150 amps
Battery: Die Hard stock size for car
Amp: Crescendo BC3500d
Big 3: NO
Wiring: 300amp fuse- 1 run of 1/0 and one run of 4 ga. (when I was running the 1/0, I said well hell, might as well leave the 4ga there and use it. more copper=better
The highest clamp I have done was 2100w which im sure is all my electrical system can support. Now at the same time, I did not clamp it at any frequency below 40hz, so it could likely be higher on a 35 hz tone around the tuning of the barrel.
Note: When I first got the amp, I had only the 4 ga for 2 days, and was waiting on my 1/0 to show up in the mail, I also only had a 125 amp fuse on the amp, I could not pop the fuse, the wire would not let enough current go through to allow the amp to blow it. So technically the amp could have only produce approx. around 1,500w tops off that wire and 125 amp fuse.
So, so far, off of my stock electrical, leaving voltage drop out, if i go based off of 12.5v, I've carried approx 168 amps to the amp.
then if I went based off of an idle at 13.8, thats approx 152 amps. (again leaving out voltage drop)
So in my theory, and very little recorded data, I can tell pretty accurately that I only get about as many amps as my alternator can produce back to the amp.
Edit:
Also, I am in the process of picking out battery power and a 300amp alternator for this season,
Alt: 140 amp
Batts: Xs 3000xp and 5100
Amps: Dc 3.5k and stock Mids highs amp(300 watts iirc)
Big 3 done
1 pos and 1 neg run to back batt
Max voltage drop is a little under 13v surprisingly
1997 Trans Am WS6
Pioneer DEH-P5200HD
2 DC Level 4 M2 12s
4 cubes tuned to about 34hz
DC 3.5k
1/0 Welding Supply Ultra Flex
Stock 140A alt
Stinger Fuses & Fuse Holders
XS Power D5100
XS Power XP3000
Big 3: NO
Edit:
That's a nice stock alt. Mine is only a 90A.
But still, running 3500w off stock electrical is pretty awesome, even if your not getting full power out of it. iirc I saw someone on here that was running around 5k, but had like 2 or 3 xs batteries.
110alt
1000.bd RF power
400.4 RF power
stock batt up front xs power 1200 in back 0g front to back 4g to amps
full tilt drops to 12.8 and no big3 yet
running 2sa8v.2
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
LOL I was reading your post and then I was like "wtf - what barrel???" but then I realised it was YOU lol. haha.
LOL, yea, i gotta quit calling it a box, cause a box it is not.. LOL
Big 3: NO
Edit:
Yea man, my first step is getting a 120lb northstar battery, Im working on that now, I will see what that bastard puts out then, the battery is 7000-8000 cranking amps. I ran one back in the day. We will see hwo much better that is, then go for the alt. Im kinda doing this one step at a time to have the enjoyment of watching the increases, and testing, I like to piddle around.
Alt: 130A
Oreilly Super Start Extreme
AQ 2200
MB Quart ONX4.80
Voltage drop lowest Ive seen is 12.49V
NO big 3,
NO 0ga.
Running Knu 4ga from battery to 2200 and from battery to MB Quart
300A fuse for 2200
100A fuse for MB Quart
Also have LED lighting for underbody, wheel wells, under the hood, bed, 2 15" monitors, and HID headlights.
  • Who's Online   0 Members, 0 Anonymous, 338 Guests (See full list)
