Skar 15 VVX Loudest output box
Have a single 15 vvx sub ive had laying around for months now.
I swapped it originally when i got it with a friends setup i did where i had 800rms to a single kicker 15 cvx 3.5 net box, 15 inches of port per, tuned to 36hz and i just liked the kicker better in that box than this skar since i could tell the kicker was a lot more louder in the 38hz plus range.
I put the skar away and i now want to get a setup going with it.
Question is what is the loudest ouput for a daily driver on all kinds of music from rap to rock for a single skar vvx 15 box specs?
Should i go 3 cubes net tuned to 32hz, or make the box bigger and tuned higher? Space is not a problem and power will be 600-750rms.
Also would sealed work for loudness from lows and higher? If so 2 cubes net or bigger/smaller?
Thanks.
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Based on your music listed I would go ported tuned at 35Hz seems to be a real nice happy medium for playing from rock to rap as you said. So I would try 3cubes tuned at 35Hz, you can do aero ports and be able to later adjust the tuning if you used DUCT (not duck) tape on the port flares and then changing the inner tube section to a different tuning, just be sure to use at least 3 layers per flare to ensure a nice seal.
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
Anymore skar opinions on getting the most daily driver loudness i can with this sub?
If i were to reach for a 3.5 cubes net box what tuning should i lean for? still 35hz or can i go 32-33hz.
I want to make a box where i can also be in line with specs for some other subs i have.
Im sticking to 12 inches of port area per since i usually build in the 15-16 per range.
  • Who's Online   2 Members, 0 Anonymous, 1537 Guests (See full list)
