skaraudio Posted January 31, 2013 Report Share Posted January 31, 2013 The time has finally come to announce full specifications as well as pictures on the completed VVXv2 Subwoofer line up! We will not be doing a Pre-Order on these right now, but they are due soon! ETA : March 5th, 2013 Web Link Nearly two years has passed since we initially launched the VVX Series subwoofers, and ever since the launch, they have been making waves in the car audio community everywhere. We are now proud to announce the launch of what our engineers have been working on for more than one year now…The VVXv2 Subwoofer line up! The VVXv2 was redesigned from the ground up to innovate and improve on every aspect of our 600 Watt RMS line up. The Skar Audio VVXv2 Series subwoofers were designed to withstand brutality, sound amazing, and recreate low end response that will make your car tremble. With a completely unique new basket & design; the woofers are capable of enormous excursion, creating earth shattering responsive bass. They feature a brand new competition grade foam surround which is very accurately stitched to its premium paper cone. Utilizing a three piece ferrite magnet motor assembly along with a 2.5” voice coil, the vvx series is conservatively rated at 600 watts RMS power! The VVXv2 lineup is available both in Dual 2 Ohm and Dual 4 Ohm Voice Coil configurations and comes in 10”, 12”, and 15” sizes. Whether you are looking to do a single subwoofer for that extra bass in your daily driver, or if you want to run sixteen of these woofers in a competition vehicle, the VVXv2 series will always impress! Pricing Will Remain the Same as the VVXv1 once these arrive - but so many new features :-) Technical Specifications Available in D2/D4 Voice Coil Configurations 600 Watts RMS Power 2.5" Voice Coil Triple Stack Ferrite Magnets (160mm * 20mm x 3) Double Layer Spider Premium Grade Foam Surround High Quality Paper Cone Xmaxx : 26.5mm VVXv2-10 D2/D4 Re : 1.8+1.8 Ohms/3.2+3.2 Ohms Res : 35.1 / 39.5 Ohms Qms : 0.317 / 0.326 Qes : 0.294 / 0.258 Qts : 0.327 / 0.301 Rms : 5.8 / 5.2 kg/s Cms : 0.28 / 0.26 mm/N Mms : 337.4 / 326.2 gr Nref : 0.19% / 0.17% Bl : 26.9 / 28.2 n/a Spl : 87.4 / 88.2 dB Vas : 41.6 / 39.5 L Rp : 20.1 / 22.9 Ohms Lp : 29.8 / 28.4 mH Cp : 683.9 / 724.1 uF Le : 2.67 / 2.41 Mh Xmax : 26.5mm VVXv2-12 D2/D4 T//S Paramters D2/D4 Re : 1.8+1.8 Ohms/3.2+3.2 Ohms Res : 39.5 / 45.6 Ohms Qms : 0.395 / 0.371 Qes : 0.315 / 0.278 Qts : 0.38 / 0.315 Rms : 5.93 / 5.4 kg/s Cms : 0.29 / 0.23 mm/N Mms : 382.5 / 365.6 gr Nref : 0.21% / 0.156% Bl : 26.1 / 27.4 n/a Spl : 87.2 / 87.9 dB Vas : 71.3 / 65.8 L Rp : 22.5 / 25.6 Ohms Lp : 30.6 / 32.6 mH Cp : 722.7 / 852.3 uF Le : 2.18 / 2.60 Mh Xmax : 26.5mm VVXv2-15 D2/D4 T//S Paramters D2/D4 Re : 1.8+1.8 Ohms/3.2+3.2 Ohms Res : 42.3 / 56.5 Ohms Qms : 4.23 / 3.256 Qes : 0.776 / 0.685 Qts : 0.45 / 0.39 Rms : 7.2 / 6.4 kg/s Cms : 0.45 / 0.36 mm/N Mms : 346.5 / 325.3 gr Nref : 0.18% / 0.14% Bl : 23.5 / 25.7 n/a Spl : 86.5 / 87.8 dB Vas : 268.2 / 253.9 L Rp : 38.2 / 34.5 Ohms Lp : 53.5 / 45.6 mH Cp : 1295.5 / 1203.2 uF Le : 3.09 / 3.6 Mh Xmax : 26.5mm Skar Audio www.SkarAudio.comPhone : (888) 501-7527 Link to comment Share on other sites More sharing options...
Nate Futuristic Posted February 1, 2013 Report Share Posted February 1, 2013 26.5mm Xmax?????? For realz? down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies Link to comment Share on other sites More sharing options...
andygardner Posted February 2, 2013 Report Share Posted February 2, 2013 I love that black dust cap. Looks amazing. Link to comment Share on other sites More sharing options...
WillPwn4Food Posted February 11, 2013 Report Share Posted February 11, 2013 26.5mm Xmax?????? For realz? That's Exactly what I was thinking. From 21 to 26 on 600w with a 2.5" coil. Hot diggidy damn. Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus. Link to comment Share on other sites More sharing options...
crazydoublekick Posted February 11, 2013 Report Share Posted February 11, 2013 26.5mm Xmax?????? For realz? That's Exactly what I was thinking. From 21 to 26 on 600w with a 2.5" coil. Hot diggidy damn. I noticed that first as well. Damn, I want a pair. 1993 Suburban 6 Crossfire XT3 15s Crossfire XS-16k Crossfire mids & highs and amps 65ah Cmax bank Iraggi 320a and Mechman 300a Link to comment Share on other sites More sharing options...
bamapride427 Posted February 12, 2013 Report Share Posted February 12, 2013 looking legit Link to comment Share on other sites More sharing options...
WillPwn4Food Posted February 17, 2013 Report Share Posted February 17, 2013 I'm not a fan of the completely black dust cap. I'd have to bring it to a paint shop to have some custom airbrushing done. Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus. Link to comment Share on other sites More sharing options...
zydrix Posted February 17, 2013 Report Share Posted February 17, 2013 I still like the inverted dust caps that were on the vvx V1. But these seem awesome!! My build 98 s10 2.2 3 american bass HD 15s with psi soft parts. (on there way here) atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build) alpine 6.5s in doors infinty 4x6s in dash. clarion cz201 HU. mechman 240a H/O alt stuff i still need. SHCA 2/0 wire SHCA 1/0 to 2/0 adapters Atomic AT-3000.1 Lots of sound deadner new mids an highs, still debating on what to do. A few Deka g31 batts. Link to comment Share on other sites More sharing options...
WillPwn4Food Posted February 17, 2013 Report Share Posted February 17, 2013 I still like the inverted dust caps that were on the vvx V1. But these seem awesome!! Same here. I'll probably order the v1's still just for that reason. Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus. Link to comment Share on other sites More sharing options...
sayhuh? Posted February 17, 2013 Report Share Posted February 17, 2013 Kevin Not sure it's been asked or not, but will the V1s be able to be recone with V2 softs? I need that all black everything look. Blown Link to comment Share on other sites More sharing options...
