Ghoagland Posted March 4, 2013 Report Share Posted March 4, 2013 I would like someone to design a box for a zvx 15 that is ported at @32hz and is 3 ft^3, the cut out is 13.9, sub woofer displacement is 0.17 ft^3 , and the mounting depth is 9.3. It will be a trunk box so port back sub back and would like it to be double baffled, willing to pay for a good design thanks!!!! Will be running an aq2200 in a 1995 toyota avalon xl Link to comment Share on other sites More sharing options...
Joe X Posted March 4, 2013 Report Share Posted March 4, 2013 Post max dims for a box, amp model, trunk car model. Link to comment Share on other sites More sharing options...
Joe X Posted March 4, 2013 Report Share Posted March 4, 2013 So here is a suggestion: Enclosure Specifications:Fb = 32.5 HzVb = 3 ft^3External Height = 17 inExternal Width = 30 inExternal Depth = 20.5 inPort Width = 3 5/8 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Front & Back (3 parts) = 30 x 17Left & Right Sides = 18 1/4 x 15 1/2Top & Bottom = 30 x 18 1/4L Port Internal Assembly Parts:Front to Back = 14 5/8 x 15 1/2Extension = 18 1/2 x 15 1/2 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.- The port needs 3 5/8" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
Ghoagland Posted March 4, 2013 Author Report Share Posted March 4, 2013 Wow you went out of your way on that Link to comment Share on other sites More sharing options...
Joe X Posted March 4, 2013 Report Share Posted March 4, 2013 A bit, if you want (and can) do the recommended high efficiency port shown, I need to provide a detailed diagram for it otherwise build like this: Link to comment Share on other sites More sharing options...
