Smoove Posted April 27, 2014 Report Share Posted April 27, 2014 Unfortunately no the AVBM will not work on a stock alternator Does this mean I have to have a Mechman Alt to use an AVBM / AVBM II in my 1996 C1500 5.7 silverado? Quote 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
MECHMAN Posted April 28, 2014 Author Report Share Posted April 28, 2014 If the alternator is an OE alternator from GM yes it will work. If its a "factory replacement" like from a parts retailer it may or may not work Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
dharris2488 Posted June 24, 2014 Report Share Posted June 24, 2014 Just want to make sure the regular AVBM, with set screw will work on my Toyota Camry 2013 with a S Series Mechman 240amp alt? This won't fry any of my internal electronics will it? I would LOOOOOVVVVEEEE to actually see above 13.5 volts in my car!!! So frustrating... I'm talking about buying the original AVBM, not this one with the dial and volt meter. Will someone chime in and let me know if it will work? Thanks! Quote 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere Link to comment Share on other sites More sharing options...
feathered1iron Posted September 14, 2015 Report Share Posted September 14, 2015 Can someone explain the benefit of this to me? Complete newb here Quote Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights Link to comment Share on other sites More sharing options...
