Hello, I'm about to order a sundown z v3 sub
and I've got a 4.5 cubic feet box (after the sub displacement and ports, 4.5 only for the sub)
I want the sub to be as louder as posslble, for daily use and I cant decide which sub to take.
on sundown website it says 4 cf box for 18" ported.
I want to play low and not 50hz+, more like 30-40 hz
my box is total of 5.5 cubic feet, two round ports (pipes) 6" x 25.6" (by my calculations the box is tuned to 33 hz)
I dont know which sub will give me better results.
should I take the 18" ?
should I take the 15" and make the ports longer?
should i take the 15" and leave the box as it is?
my amp is 1.6k and I've got XS Power D2400 battery, if it matters.
any ideas or directions?
Thanks!
Your guna want way more power on that zv4 FYI
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
I really wanted 18", but there is not enough space in my trunk for 6 c.f box
I thought maybe 4.5 would be enough.
I'll probably go for the 15"
how much would a flared port will affect?
the ports I've got are normal, no flared end
4.5 is quite big for a z v.3 15 but eater way you go v.3 v.4 there going to want more power than that.
2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood
Mike Singer 250A SHCA and KnuKonceptz wire Big 4+
AQ / Dayton pro mids+monsoon tweets
My Build : http://www.stevemead...35#entry1989435
I want to take the Z v3 18" !!!
I'm thinking about building a new enclosure
with MDF 0.75" I can have max of 6.5 cubic feet (before taking off sub displacement and ports)
and If i go on 1" MDF, I can have 6.2 cubic feet (before sub and ports)
sub displacement = 0.16
ports are - 0.81
both are around 1 c.f
so it means with MDF 0.75" its 5.5 c.f for sub
and with MDF 1" its 5.2 c.f
that would be enough? or still not ?
I have around 1 week to decide.
  • Who's Online   0 Members, 0 Anonymous, 1693 Guests (See full list)
