momofx76 Posted May 24, 2013 Report Share Posted May 24, 2013 I have a 4 channel amp that puts out 300w rms x 2 bridge mode into 4 ohms but I have 4 x 8 ohm mids rated at 150w rms each. So I would like to know a few things that I am unsure about : 1. If I run the amp bridged (2 channel mode, 300w rms x2), can I use ch 1 & 2 as a left input and ch 3 & 4 as a right input so I still have stereo sound? Will I loose stereo seperation this way? 2. Since the mids are 8 ohms, if I run them in parallel for each side (4 ohms total load) does this mean that each mid will get about 75w rms? Link to comment Share on other sites More sharing options...
Kevin M Posted May 25, 2013 Report Share Posted May 25, 2013 You won't lose any stereo separation because you are using the left and right rca's. If you run the two mids in parallel on each side at 4 Ohms the amplifier will produce 300 watts as you mentioned so each pair will see 300 watts/ 150 watts a piece. I would go easy on the gains, and have your x-over set properly. 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle Link to comment Share on other sites More sharing options...
momofx76 Posted May 25, 2013 Author Report Share Posted May 25, 2013 Thank you for the confirmation. Yes, I use a digital lcd scope to set all my gains Link to comment Share on other sites More sharing options...
