nightshadelove Posted May 25, 2013 Report Share Posted May 25, 2013 i just picked up some aa havoc 12s that i'm going to throw in my 2001 monte carlo. its going to be my first box build but i need some help with the design. i feel like the re box design site isn't too accurate and do not know how to use others so all help/designs will help. here's what i had measured from my trunk to work with, 34 inches wide, 15 inches tall, and 21 inches deep, but was kinda thinking i should double baffle the front and back? any help would be great, thanks! Link to comment Share on other sites More sharing options...
Neckbeard Posted May 25, 2013 Report Share Posted May 25, 2013 Welcome to the forum! Go download Torres box calculator thing on this site. Will help you SOOOOOOOOOOOOOOOOOOOO much Build log, Super slow!!: http://www.stevemeadedesigns.com/board/topic/168096-slow-neckbeards-1970-opel-gt/ Link to comment Share on other sites More sharing options...
nightshadelove Posted May 25, 2013 Author Report Share Posted May 25, 2013 i'm not really the greatest with the port and tuning Link to comment Share on other sites More sharing options...
Joe X Posted May 25, 2013 Report Share Posted May 25, 2013 Here is a suggestion, please read notes below: Enclosure Specifications:Fb = 34 HzVb = 2.2 ft^3External Height = 14 inExternal Width = 27 inExternal Depth = 18 inPort Width = 2 1/2 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Front & Back (3 parts) = 27 x 14Left & Right Sides = 15 3/4 x 12 1/2Top & Bottom = 27 x 15 3/4L Port Internal Assembly Parts:Front to Back = 13 1/4 x 12 1/2Extension = 9 3/4 x 12 1/2 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.- This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know.- The port needs 2 1/2" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
KiKaZz74 Posted May 26, 2013 Report Share Posted May 26, 2013 rendered the same box for you. have free time to do so. weight is ~54 lbs enjoy My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
Joe X Posted May 26, 2013 Report Share Posted May 26, 2013 Those look nice! Link to comment Share on other sites More sharing options...
KiKaZz74 Posted May 26, 2013 Report Share Posted May 26, 2013 Thank you joe. I hope you don't mind me doing tho. I might aswell use the program while I have it. Puts it into perspective of how it should look when finished. Ok no more thread jack. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
Joe X Posted May 26, 2013 Report Share Posted May 26, 2013 No of course I don't mind it's great work but if you do enough of them you will see why I usually use generic ones. Link to comment Share on other sites More sharing options...
KiKaZz74 Posted May 26, 2013 Report Share Posted May 26, 2013 Lol ok. Just gives a little better idea of what it should look like. Thats y I like doing them. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
djcue12369 Posted January 25, 2015 Report Share Posted January 25, 2015 Hello I"m looking for someone to help me with a box design, willing to pay is necessary. Any help would be great thanks Link to comment Share on other sites More sharing options...
