2003 Kia Sorento Build log (Pair of Team AA 15's in and playing)
So I got myself a newer suv ever since my dad got himself a new truck, so he gave me the Sorento. I love this suv alot, and I'm excited to start working with it and part with the Volvo very soon.
List of equipment I already have
- Audioque 120.4
- Hifonics BRZ1200.1
- 2 Skar IVX v2 15's
- Kenwood DNX7100
- Random assortments of wire/rca's
- Deka G34
Equipment I want to get soon
- Pair of Silver Flute W17RC38-04 6.5" woofers (when the 4 ohm ones get back in stock)
- Pair of Vifa NE19VTS-04 3/4" Silk Dome Tweeters
- Pac-lc1
- 150ft of 1/0 cca
- Tinned copper lugs and heatshrink
- Pair of HDC3-15's
- 2 SAZ 1500D's
Plans
- Install headunit(already have the harness and dash kit ordered)
- Install the Deka G34 as a second battery(I'll replace the stock starter battery soon)
- Big 3
- Build a new box
- Build an amp rack
- Install the mids and highs and run active with the AQ 120.4
Now here are the pictures :)
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Remove the spare and make a nice amp rack. Spare's are for pussies and you'll want to remove dead weight to minimize sag. ;)
2007 Pacifica
Spare is under the Sorento
2003 Kia Sorento
Team Subsonic Lows
I can't see the A-pillars for the tweeter installation ...
Nice ride brother !!!
So how deep is that storage bin? Still should work for amps...
It's not deep enough for the amps
Hopefully I should have something done next week, I have ordered the harness but it was the wrong one, so I ordered the right one, so need to wait longer.
2003 Kia Sorento
Team Subsonic Lows
fffffuuuuuuuuuuuuuuuuuuuu
I know the Hyundai SUVs had a plastic or foam tray you could remove from the bin. Their tires were inside as well, giving you lots of room to do whatever if you yanked it out. I guess because it's got a rear drive axle the floor is higher.
Seems like nothing I suggest will work for you, so :popcorn:
2007 Pacifica
Small update but glad I got something done so far
Installed my headunit
1026245_686356578047931_779572479_o.jpgDash kit was crappy, so I need to fix the gap on the bottom, i'll probably paint the yellow to give a shadow effect.
So far the headunit brought out the midbass off the doors, so much that it rattles the door panel with the eq at 0 lol (need to fix that), and honestly, the mids and highs sound better than the ones I had in the Volvo, think cause of better placement or imaging, something like that. This gives me a nice starting point cause if the stock mids and high sound good, aftermarket will sound a lot better, especially amped
Here's also my plans so far for the box
Main plan is to use the Skar IVX but then upgrade to Sundown SA 15's and find an AQ 2200 to match the 120.4
Though next plan for now is to get the 0 gauge, and build the box.
2003 Kia Sorento
Team Subsonic Lows
Update, spent the last 2 days doing my Big 3
some goodies, 50 ft of sky high cca 1/0, tinned copper 2/0 lugs, knu reducer, and some heavy duty heatshrinks
Stock battery resting voltage, impressive for a Group 24 lead acid
Stock charging voltage
Location of frame ground, directly at the frame itself
Used some left over techflex
Properly crimped with my 12 ton hydraulic crimper
Sanded and grinded down for the cleanest ground
Plasti dipped
2003 Kia Sorento
Team Subsonic Lows
  • Who's Online   1 Member, 0 Anonymous, 1156 Guests (See full list)
