graham0599 Posted December 29, 2015 Author Report Share Posted December 29, 2015 Equipment: Headunit- Pioner AVH-X4500BT Subs- 2 10" DC Level 3's with AR cones, 8 layer level 4 coil, and spider upgrades Sub Amps- 1 Formula X 5k Components- 1 set of Crescendo Mezzo components (replaced mids with carbon CNF 6.5's) Mids Amp- RE Audio CTX-1600.2 Power Wire- Audiotechnix 1/0 Speaker Wire- SHCA 12ga RCA- T-Spec V12RCA-202 Backup Cam- Crimestopper SV-5130.IR To-Do List: 1. Rewire 5k with Audiotechnix 1/0 2. Finish RGB's -already have working in floor boards -place by amp and in trunk 3. Redo amp rack -will hold RE Audio CTX-1600.2 and Kicker DX400.4 - DX400.4 will run the removable 6x9's, I play audio outside a lot, tailgating, volleyball and such 4. Take Pictures!!!!! 5. Replace Sub RCA's to match 6. Redo mids spacers or build cheap door pod Something like this cost $5 My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678 Link to comment Share on other sites More sharing options...
graham0599 Posted December 29, 2015 Author Report Share Posted December 29, 2015 Goals: 1. Buy DSP and run active. To do so I'd have the RE1600.2 running the mids, then there's a few options A) DX400.4 runs the 4 6x9's, Off brand 2-channel runs tweets B ) DX400.4 runs tweets on two channels and the 4 6x9's on other two channels C) DX400.4 runs tweets on two channels, 2 6x9's on other two channels, and off brand 2-channel runs other 2 6x9's The options are ranked in order. Option A provides most power to the system but idk how the 2-channel will make the tweets sound. If it doesn't meet my standards then I'll go to option B. If option B isn't loud enough then I'd throw in the other 2-channel. 6x9's main goal is volume but I still don't want it sounding like shit. 2. Port the subs and have box in rear half of the trunk instead of front My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678 Link to comment Share on other sites More sharing options...
Smoove Posted December 30, 2015 Report Share Posted December 30, 2015 You should try sealing off around the box so there is no leaking under the strut bar. That way back of the car acts like the ported side of a 4th BP with port being the space above the strut bar. I think it makes a difference in sound in my Z and my sub is sealed. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
graham0599 Posted January 3, 2016 Author Report Share Posted January 3, 2016 You should try sealing off around the box so there is no leaking under the strut bar. That way back of the car acts like the ported side of a 4th BP with port being the space above the strut bar. I think it makes a difference in sound in my Z and my sub is sealed. I'll add that to the to-do list! My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678 Link to comment Share on other sites More sharing options...
graham0599 Posted January 17, 2016 Author Report Share Posted January 17, 2016 Goals: 1. Buy DSP and run active. To do so I'd have the RE1600.2 running the mids, then there's a few options A) DX400.4 runs the 4 6x9's, Off brand 2-channel runs tweets B ) DX400.4 runs tweets on two channels and the 4 6x9's on other two channels C) DX400.4 runs tweets on two channels, 2 6x9's on other two channels, and off brand 2-channel runs other 2 6x9's The options are ranked in order. Option A provides most power to the system but idk how the 2-channel will make the tweets sound. If it doesn't meet my standards then I'll go to option B. If option B isn't loud enough then I'd throw in the other 2-channel. 6x9's main goal is volume but I still don't want it sounding like shit. 2. Port the subs and have box in rear half of the trunk instead of front So I need input on what to do here, I'm probably going to be buying the Kicker Front Row today, looks like a good deal and reliable My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678 Link to comment Share on other sites More sharing options...
graham0599 Posted January 25, 2016 Author Report Share Posted January 25, 2016 Installed some LEDs in the back, changed a couple bolts, fixed some rattles, and added some deadener. Ran out of washer so had to redneck engineer in the meantime Amp back in. Still going to rewire later so all wire matches. This is installed with old scrap pieces. Just need to buy lugs and solder All lights on white Video of the RGBs http://vid619.photobucket.com/albums/tt273/graham0599/350z%20Build/FD1007D8-1A0A-499A-90CB-E6BCEB663A57_zpsvireuwv8.mp4 My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678 Link to comment Share on other sites More sharing options...
pantantler Posted January 25, 2016 Report Share Posted January 25, 2016 nice one.. i just ordered new cob leds for all the interior off ebay the other day.. vanity, map light and new park lights should be my next post =) Link to comment Share on other sites More sharing options...
graham0599 Posted January 25, 2016 Author Report Share Posted January 25, 2016 Nice! Ya I need to order some LED bulbs My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678 Link to comment Share on other sites More sharing options...
