Pioneer AVH-X4500BT DVD bypass solution ??
Without shelling out $30 for a bypass hack on ebay
or adding a unsightly switch somewhere
My installer tried using a relay that trigers with the remote wire to send ground to the parking brake wire.
it works 50-50 sometimes i have to power cycle the headunit or remove the disc and try again seems anoying.
is this becuase the relay powers on too quickly and should power on after the deck is booted ?
Any cheaper alternatives ? or solutions guys ?
Thanks
My Build log :
http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/
Current System
2020 Ford F-150 XLT Supercrew
Audio Control Epicenter
Audio Control LC7i
Taramp PRO 2.6 DSP
Taramp DS4x800 - Highs
Taramp HD3000.1  Mids
Taramp MD5000.1 Bass
8 x DS18 6.5 Pro x6m - mids
2 x Soundsteam SST-05 Bullet Tweeter
2 x DS18 TW220 Super Tweeters
4 X SkarAudio EVL-8  BASS
Big 3
Yellow Top
I could be doing it wrong (but it works) is I just ground out the wire that is supposed to go to the parking brake. I have done it to three different brands (sound stream, alpha-nav, clarion) and they have all worked with no issues. The head Unit should come with a wiring schematic that shows the wire to the parking brake goes to the ground which engages the "bypass" for the dvd to play.
99 Navi C-Pillar Wall
2 Sundown Audio Zv4 18's D1
PPI components
1 Rockford Fosgate power T400.4
1 Crescendo 5500 (for now, another later)
3 XS Power 3400's
AlphaNav double din HU
wrong.
that pioneer unit needs a pulse of + into the parking wire that needs to go away. If you search, you will find the answer in how to do it.
I think only the older units that method works with especially pioneer that doesnt work
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
nah it still currently works on sony/kenwood/jvc and all the cheap manufactures. Pioneer is the only company who activly changes it or makes it at least a bit tricky. if you follow my first post youll get it.
Ai James where bro ? all my research shows up that i should by a $30 module from ebay :((
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
You think ?
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
  • Who's Online   2 Members, 0 Anonymous, 1442 Guests (See full list)
