OK, here's one that'll get you thinking. Hell, it's had me thinking since Electronics 101 as a Junior in HIgh School (1985 - 1986 that was . . . )
The number .707 comes up often in math (It's actually .7071067811 ... but .707 will do for this brain twister). IE - consider the following formulas, and their relationship to one another:
Power = Voltage2 / Resistance
RMS Power = (Voltage x .707)2 / Resistance
Now, when you go and square .707, you get .500 which is pretty cool in and of itself, but then when you consider that RMS Power = Peak Power / 2, you also discover that you're really dealing with the same amount of "power" . . . just discussing it differently.
For example, let's say that we have an amplifier that can deliver 10 Volts AC (IE - a sine wave that measures 10 Volts at it's Peak) into a 2 Ohm resistive load. Let's solve for Power and RMS Power:
Power = (10 Volts)2 / 2 Ohms
Power = 100 / 2
Power = 50 Watts
RMS Power = (10 Volts x .707)2 / 2 Ohms
RMS Power = (7.07)2 / 2 Ohms
RMS Power = 50 / 2 Ohms
RMS Power = 25 Watts
Therefore, we've proved that 50 Watts "Peak" = 25 Watts RMS.
There are numerous mathematical equations at which the result is .707 . . . who can name a few?
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
A 3db decrease in power ends up with the output voltage being reduced by a factor of 707. Useful trick to know when setting crossover points.
It's also the conversion factor from peak to peak (square wave) voltage to RMS(sine wave) voltage. Works great for setting amps with a DMM. Measure the rail voltage, do the conversion, adjust the gain accordingly, boom done. It's a bit more accurate then trying to use the traditional DMM method IMO. Especially in amps that are underrated and trying to adjust the gain to a preset number will end up with clipping in an attempt to get the desired output voltage
The sine of 45 degrees is .707
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
Qtc of .707 is a magic number for best response in a sealed enclosure.
Like cleansiera mentioned, it's also the Second-Order Butterworth, which is for max flat amplitude response.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
and the cosine . . .
you sir are correct :P
i love reading your stuff, even though it takes me a while and a couple hundred re reads to understand it.. haha
 Share
