sahargt Posted September 21, 2013 Report Share Posted September 21, 2013 HiI'm new hereI think the upgrade Alternator honda Civic Engine Size: 1.8L : 2009 version of Europe Vehicle equipment thatIncluding improving the vehicle's Electricity/ electrical system SUNDOWN AUDIO SAX-125*4Sundown Audio SAZ1500DV3SA-12D4 *TWO XS 5100Big 3 So who to buy? mechman singeralternators Link to comment Share on other sites More sharing options...
Watch the bass Posted September 21, 2013 Report Share Posted September 21, 2013 Or DC Power, shoot them mail´s or use there productfinder´s and compare the offer´s. "in the abundance of water, the fool is thirsty" Bob Marley Link to comment Share on other sites More sharing options...
inferno1985 Posted September 21, 2013 Report Share Posted September 21, 2013 Hi I'm new here I think the upgrade Alternator honda Civic Engine Size: 1.8L : 2009 version of Europe Vehicle equipment that Including improving the vehicle's Electricity/ electrical system SUNDOWN AUDIO SAX-125*4 Sundown Audio SAZ1500DV3 SA-12D4 *TWO XS 5100 Big 3 So who to buy? mechman singeralternators mechman and singer are pretty good both ways, from what ive heard me im planning on gettin a mechman when i get the money here in a week or so. Link to comment Share on other sites More sharing options...
zydrix Posted September 21, 2013 Report Share Posted September 21, 2013 U CAN'T go wrong with either. I was planning on going with singer alts! But I got a nice deal on my mechman an it fit my budget just right at the time. Both companies make amazing alts, an both companies customer service is great! Just comes Down to what U WANT an what U WANT to pay. My build 98 s10 2.2 3 american bass HD 15s with psi soft parts. (on there way here) atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build) alpine 6.5s in doors infinty 4x6s in dash. clarion cz201 HU. mechman 240a H/O alt stuff i still need. SHCA 2/0 wire SHCA 1/0 to 2/0 adapters Atomic AT-3000.1 Lots of sound deadner new mids an highs, still debating on what to do. A few Deka g31 batts. Link to comment Share on other sites More sharing options...
sahargt Posted September 21, 2013 Author Report Share Posted September 21, 2013 mechman 170/240170 amp300 rpm turn on500 rpm - 120 amps800 rpm - 150 amp1200 rpm – 170 amps$449240 amp500 rpm turn on650 rpm - 100 amps800 rpm - 140 amps1500 rpm - 240 amps$549Those vehicles have a pretty low idle speed, and a relatively small crank pulley, so I generally recommend either the 170 amp or the 240 amp S series unit if you want really good output below 800 engine RPM. Both units are pretty much indestructible, even in hot climates. All the S series units feature our twin heavy duty internal rectifiers, oversize charge post, billet aluminum overdrive pulley, hairpin stator, and 12 massive diodes. We include a 2 year warranty, and a 1/0 gauge cable connection with every unit. The price also includes the necessary vehicle specific adapter bracket and plug-n-play wiring harness. Because the drive belt on those cars is so narrow, you may experience some belt slip with the 240 amp unit when it is under a heavy load. We offer a 320 amp unit, but it will pretty much slip the belt all the time.singeralternatorsYour alternator is PCM controlled for voltage but you may either do a one wire bypass design or a external regulator (this sometimes can trip your battery light on since your going around the computer) Lead time is between 2-3 weeks to do the build.The 1 wire bypass allows you to set voltage between 12-15V and is a 39 option to addThe external regulator adjusts from 12-20V and is a 139 option to add (has knob you can run into the vehicle for voltage adjustment)The upgraded unit that I offer for your vehicle is a 160A (175A peak). This alternator is a direct bolt on design for your vehicle and would plug in just like the factory alternator.I include my overdrive pulley to boost the idle output (this will spin the alternator faster at low RPMS to boost idle output by around 30 to 40A more then the stock will). The total price on this unit shipped w/ my lifetime warranty on labor is 449 (shipped anywhere in the states).All units come w/ a lifetime warranty that covers any repair labor (parts are at company cost) You can add a powder coating option on any order for an additional 48. Link to comment Share on other sites More sharing options...
