STEALTH808 Posted September 25, 2013 Report Share Posted September 25, 2013 if you need to run a thin wire through firewall or dash then straighten a metal hanger, then tape the wire to the hanger and run it through that way. Or buy a grommet tool? hehe yeah, obviously if you dont have one.. hehe obviously. Quote TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET 150Db Club 160Db club in the future I see krakin as a threat Link to comment Share on other sites More sharing options...
meade916 Posted September 25, 2013 Report Share Posted September 25, 2013 homemade tweeter savers a standard car dome light in line with your tweeters positive terminal. It acts like a resistor that changes impedance as it gets hot and starts to glow. When the impedance rises, it causes the amp to put out less power, keeping the tweeter in check. If you push it too hard still, the bulb will pop and NOT the tweeter. Get a new bulb, set your gains better, and you are back in business. click here for an example. http://instagram.com/p/bzLpBJEt1w/ 3 Quote All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916 Link to comment Share on other sites More sharing options...
mothra Posted September 25, 2013 Report Share Posted September 25, 2013 low power 4 channel amp install in a car with rear deck speakers. jump the wires on the harness. you just need to run wires from the amp to the rear deck speakers and the leads that are now for the front speakers. using a small piece of electrical tape to wrap around a drill bit to create a drill stop at any depth. Quote if nothing changes, nothing changes You don't know what you don't know, till you don't know Link to comment Share on other sites More sharing options...
ham4864 Posted September 25, 2013 Report Share Posted September 25, 2013 mix mdf sawdust with wood glue to make your own mdf putty. i bet that would be strong as hell,what are some uses? Quote 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6 Link to comment Share on other sites More sharing options...
shogen Posted September 25, 2013 Report Share Posted September 25, 2013 fill gaps... seal edges/corners mix mdf sawdust with wood glue to make your own mdf putty. i bet that would be strong as hell,what are some uses? Quote Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true. Link to comment Share on other sites More sharing options...
Krakin Posted September 25, 2013 Report Share Posted September 25, 2013 mix mdf sawdust with wood glue to make your own mdf putty. i bet that would be strong as hell,what are some uses? I do it for securing the inside gap of aeroports in boxes or to supports. Quote Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener. Link to comment Share on other sites More sharing options...
1two3 Posted September 25, 2013 Report Share Posted September 25, 2013 Soldering all connection! Crimping as little as possible. Needless to say its a much stronger and more connective connection that won't come apart due to vibrations. You guys at sonic are awesome, I always shop there. Keep up the good work! Quote Car: 2000 Honda CRV Battery: XS Power D5100R Alternator: Stock 90A Head Unit: Pioneer DEH-X9500BHS Front Speakers: Alpine Type S Rear Speakers: JBL GTO 628's Wires: All Knu 4g. Soon to be 0g. Big 3 in 0g Volt Meter: SMD VM-1 Amps: Rockford Fosgate T400-2, T1000-1bdCP Subs: 2 SSA XCON 15's Sealed Tint: Privacy glass + 5% in the back and 25% in fronts Link to comment Share on other sites More sharing options...
1two3 Posted September 25, 2013 Report Share Posted September 25, 2013 Also proper gauge wire for application, using ofc not CCA, proper fusing, sanding paint off grounds and then covering it with a conductive lubricant so it doesnt rust. All I can think of for now Quote Car: 2000 Honda CRV Battery: XS Power D5100R Alternator: Stock 90A Head Unit: Pioneer DEH-X9500BHS Front Speakers: Alpine Type S Rear Speakers: JBL GTO 628's Wires: All Knu 4g. Soon to be 0g. Big 3 in 0g Volt Meter: SMD VM-1 Amps: Rockford Fosgate T400-2, T1000-1bdCP Subs: 2 SSA XCON 15's Sealed Tint: Privacy glass + 5% in the back and 25% in fronts Link to comment Share on other sites More sharing options...
ham4864 Posted September 25, 2013 Report Share Posted September 25, 2013 homemade tweeter savers a standard car dome light in line with your tweeters positive terminal. It acts like a resistor that changes impedance as it gets hot and starts to glow. When the impedance rises, it causes the amp to put out less power, keeping the tweeter in check. If you push it too hard still, the bulb will pop and NOT the tweeter. Get a new bulb, set your gains better, and you are back in business. click here for an example. http://instagram.com/p/bzLpBJEt1w/ will this work if you gave a bass blocker on the positive lead also Quote 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6 Link to comment Share on other sites More sharing options...
graham0599 Posted September 25, 2013 Report Share Posted September 25, 2013 Take like 5' of solder and fold it to around 1' and spin it with a drill. Really helpful when soldering 1/0 lugs Quote My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678 Link to comment Share on other sites More sharing options...
