I am having trouble fitting two 12 inch subs and a 6-inch aero port into my front baffle. The aero port has a 8.25 inch cutout and 9.25 inch diameter. This is becoming an issue because I am limited by the size of my front baffle fitting into my trunk.
I am thinking about leaving the internal flare on the aero port inside the box but removing the outer flare outside the box. If I do this I only need a 6-inch cutout rather than the 8.25 inch cutout. This will free up some space on my front baffle and I can fit my two 12's.
Am I defeating the purpose of the aero port dynamics if I remove the outer flare? Will I lose db gains and increase the risk of port noise?
Thank you in advance for all the help.
I wouldn't say ur defeating the purpose, but it won't sound as good. If ur tight on space do a slot port.
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
You will cause more turbulence if you get rid of the flare, which in turn can lead to a lose of output.
I also haven't heard of slot ports being more efficient or space saving compared to aero-ports.
Krakin's Home Dipole Project
From my experience you can always go deeper into a trunk build, but not necessarily wider. If he goes deeper into the trunk he can only give up say 5 in of width in the front and have enough room to mount the subs with plenty of clearance from the port. S
Subs/Amps: TBD
Depending in the car/trunk. Can always look into porting to the side
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
Thanks for all the replies so far.
I am facing the subs and port into the cab and sealing off the trunk. My rear seats fold down completely.
If I move the front baffle right behind my rear seat bracket I can get a great seal, but the height and width are limited.
If I move the box back about 10 inches I have more width and height, but the box will be more difficult to seal and deeper in the trunk. I worry I may lose db gains in this position.
Any other opinions would be greatly appreciated.
  • Who's Online   0 Members, 0 Anonymous, 303 Guests (See full list)
