My box designs and questions for 2 sa-8s in a reg cab Ranger
Ok second design. Now this one took some thought. I hated how my seat had to be moved forward so that the excursion of the subs wouldnt come into contact with it. So I opted for a down fire box with a external, tunable port. This one is also 1 cube net and currently tuned to 32. Its currently in my truck
Ok so here is my problem. No matter how I tune these ports, its a low end monster. Sure, it will shake the hell out of the truck like a pair of 15s, but it doesn't get loud, or sound good on anything other then "rack city" type songs. I have tried shorting the ports with no success. I would like to listen to all kinds of music and it sound good and get loud. Why is it doing this? I'm also playing around with a single sa8 in a 4th order design for the ranger. But I know that will not help with sq!
A 4th order has more sq than a ported box. And since u have the material to play with see if a sealed box works better for what u want. If u don't like it, then don't use it. I bet it will sound better than it does now tho.
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
Not really sure.on the only playing low but i have had success firing at the b-pillar like cleansierra said actually iirc last year when i first posted on here cleansierra told me about firing to the b-pillar
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
sealed will kill my output. Not sure If I want to go that route
you mean firing the ports at the b pillar or both sub and port? Because my port is currently firing at the driver b pillar.
If you have the space and subs will allow try a 4th order if you have not already
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
