fritosaregood Posted November 2, 2013 Author Report Share Posted November 2, 2013 Mine had the same black stuff leaking, but only because it got punctured on the bottom. Xs told me to seal it with a plastic epoxy, I did and its been fine ever since Just the 5 minute epoxy for plastics? Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
SnowDrifter Posted November 2, 2013 Report Share Posted November 2, 2013 First off: sprinkle baking soda and water on whatever it spilled on. If it's acid, you'll know because it foams. And if that's the case, you want to neutralize it so it doesn't eat through anything. It could very well be acid, but I'm surprised it's leaking. Those batteries are sealed except from over-pressure vent caps under the sticker that goes across the top of the battery. I'll wait for Nathan to chime in though. I don't want to speak for him Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
tacomaguy1 Posted November 2, 2013 Report Share Posted November 2, 2013 Mine had the same black stuff leaking, but only because it got punctured on the bottom. Xs told me to seal it with a plastic epoxy, I did and its been fine ever since Just the 5 minute epoxy for plastics? Yeah I didn't see it physically leaking but knew it did. They were in a wooden box and when I pulled them there was a black stain under it and like dried black stuff Think I drilled into it from underneath, fail Forgot exactly what xs said but just told me to seal it up and run it Quote Team Flex Issues Link to comment Share on other sites More sharing options...
