Bump4life's SuperCapacitor Overview and Testing
I've been testing and testing Supercaps all year and so far the best results are Batts+ Caps together.
Criteria for "Good" is avg. power over time, consistent power curve over time, reliability, charge efficiency, peak power, and duration of play.
maybe you can bring some points to the table then so i can add to the intro!
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Can't release any of my test notes or too much info until the products release Jan 14.
But
In a standard vehicle charging system. (12V batt and alternator), Caps can be used to reduce stress and duty cycle posed on the battery during times of charge/ discharge.
This extends the life of the battery and maintains a higher voltage over time.
Different ratios of cap size to battery size can be used for different goals for the electrical system.
Large batts with small caps are useful as a buffer which extends battery life by reducing strain on the battery. This will also level the power curve over time to a small amount over what a battery alone can deliver. Very useful for low-mid level power audio systems that play music daily only.
Small Batts with Large Caps or many banks of Caps are useful for peak power in short bursts with the ability to play long periods at a lower power level but still a higher power level than when using batteries alone. This is more of the high powered cars that compete in SPL and also play daily music.
A More equal ratio gives a much more flat power curve over time at a substantially higher level than when using batteries alone. Since the caps charge faster than batts and drain on the batts is limited, re-charge times are decreased, making voltage available on demand during high powered music sessions. This is useful for any power level demo system or daily play ground pounder types.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
But
when you say equal ratio, do you mean equal in joules/stored energy? or how are you comparing batteries to capacitors? in what units are you comparing to say x capacitors equals x batteries?
BMW M340 xDrive
Soooo. I have 2 banks of the 2.5, 2500F. If I wanted to add on and can only find the newer, higher voltage ones, can I run them together since I will be charging at the same voltage anyways? if not I will have to scrap 12 perfectly good caps....
But
F to aH
50F is balanced to a 20aH Batt.
200F to a 80aH Batt
500F to a 200aH Batt.
Small Batt to large Cap ratio would be 500F to 20aH
Large Batt to small Cap ratio would be 50F to 200aH
Or any figures similar to those.
Ed Lester
ShowtimeSPL Host
My old Build Log
But
F to aH
200F to a 80aH Batt
awesome. thanks for that insight!!
you can add on. no issues. you just cant charge over 15 volts.
BMW M340 xDrive
The downside of using batteries and caps is the potential difference. Caps stay at the charging voltage even when not being charged. Batteries drop back down to resting voltage. So what you get running both is the alt charging the caps which charge the batts and essentially render them useless because batteries love being charged and will take quite a bit of power. Now that being said using caps without batteries means you need more charging to keep the voltage in a safe range, but this is in turn a good thing because let's be honest running 10k on a couple batteries and an upgraded alt is not proper electrical. Caps are better than batteries given you have the ability to properly run the power you have. They do fine for daily as long as you can charge them correctly and have enough reserve for your power.
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
I'm in on the Group buy if the price comes down enough, I made a thread about this awhile ago and wanted to do this, I want about 6 cells of the 3000 farad caps, but really depends on what it would cost if I did this,
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
