MrSkippyJ Posted November 23, 2013 Report Share Posted November 23, 2013 No, you don't need 2 fuses. You only need 1 fuse on the positive wire going to the amp, and it should be as close to the battery as possible. ^^ this. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
81000D Posted November 23, 2013 Report Share Posted November 23, 2013 So how is that fuse any better than the ceramic ANL fuses that I use krakin??? Link to comment Share on other sites More sharing options...
hazestorm23 Posted November 24, 2013 Report Share Posted November 24, 2013 So how is that fuse any better than the ceramic ANL fuses that I use krakin??? Some fuse ratings are off and pop with less or more power that's from my experience so its a risk buying cheapies Link to comment Share on other sites More sharing options...
BASShead12 Posted November 24, 2013 Author Report Share Posted November 24, 2013 So where would I get some of these legit anl fuses? Hu: Alpine CDE-141 Eq: Clarion EQS-746 Mids/Highs: Alpine SPR-50c 5.25" components Mids rear: Alpine SPR-69 6x9 Mids amp: Alpine MRX-F65 Power/Ground: Massive Audio 4 AWG Signal Cable: Massive Audio 14 Gauge RCA's: Monster cable Subs: 2 Rockford Fosgate HX2 12's Sub amp: Crescendo BC2000D Custom box - Herculiner with Silver port Big 3 and power/ground - Sky High Car Audio 1/0 OFC Coming soon: H.O Alternator Singer or Mechman Link to comment Share on other sites More sharing options...
hazestorm23 Posted November 24, 2013 Report Share Posted November 24, 2013 Rockford makes some good anls just try to look for known brands usually they will be a bit more costly but worth it. Link to comment Share on other sites More sharing options...
sayhuh? Posted November 26, 2013 Report Share Posted November 26, 2013 Yea man make sure you buy legit fuses and fuse blocks otherwise the ratings could be off and you might not get full power ran all the way to your amp wait what? My head hurts. Blown Link to comment Share on other sites More sharing options...
hazestorm23 Posted November 27, 2013 Report Share Posted November 27, 2013 Yea man make sure you buy legit fuses and fuse blocks otherwise the ratings could be off and you might not get full power ran all the way to your ampwait what? My head hurts.I bet. Have you not ever seen the cheap anls the sell on eBay like 20 for like 5 bucks rated at 250 amps? Yea not buying that sure as hell not trusting them Link to comment Share on other sites More sharing options...
BASShead12 Posted December 2, 2013 Author Report Share Posted December 2, 2013 No, you don't need 2 fuses. You only need 1 fuse on the positive wire going to the amp, and it should be as close to the battery as possible. No, you don't need 2 fuses. You only need 1 fuse on the positive wire going to the amp, and it should be as close to the battery as possible. ^^ this. so what if i had a distributor block to give power to my mids amp and sub amp? then would i need an additional fuse after the distributor block to my sub amp? the block is just one input, two outputs with no fuses on it Hu: Alpine CDE-141 Eq: Clarion EQS-746 Mids/Highs: Alpine SPR-50c 5.25" components Mids rear: Alpine SPR-69 6x9 Mids amp: Alpine MRX-F65 Power/Ground: Massive Audio 4 AWG Signal Cable: Massive Audio 14 Gauge RCA's: Monster cable Subs: 2 Rockford Fosgate HX2 12's Sub amp: Crescendo BC2000D Custom box - Herculiner with Silver port Big 3 and power/ground - Sky High Car Audio 1/0 OFC Coming soon: H.O Alternator Singer or Mechman Link to comment Share on other sites More sharing options...
goldeneye4564 Posted December 2, 2013 Report Share Posted December 2, 2013 i have a fuse on my run to my battery bank in the rear. from the battery bank i make 3 ft runs to my amps.... no fuses edit: i barely drop below 12.9 volts. I RREEALLY ANGRY WIT U PHOTOBUCKET. HAD TO USE DROPBOX NOW HOLYYYYYY. Wanna ride bikes? Quote On 9/16/2017 at 3:28 AM, Jake Pace said: Oh i know how a 12v system works I did take 3 years of electronics in High school hands on and some in college and also worked on cars in college an always got A's to B's in each class. But oh well enough dealing with ppl who have probably not even lived as long as ive been into electronics! On 7/8/2013 at 4:01 AM, Banshee421 said: Do horns get low Link to comment Share on other sites More sharing options...
Popwarhomie Posted December 2, 2013 Report Share Posted December 2, 2013 You dont need 2 fuses. Just one close to your front battery. If you are running a rear battery as well then yes I would put one close to the rear battery running to your amp as well. 2010 Focus coupe- 8 12" wall. 157.5@46hz 2016 Focus ST - SQ build. Link to comment Share on other sites More sharing options...
