Skar Audio VVXv2 Series Box Designs & Cut Sheets
Today I put together box designs along with cut sheets for the VVXv2 Series Subwoofers, in both Single and Dual Woofer Designs...
If you are looking for a strong and great sounding enclosure for your VVXv2 woofers, these will be perfect depending on how many and which size woofer you are running as they were designed specifically for these drivers =). Simply browse the designs below and click the associated link for the PDF File which will give you the cut sheets as well as other specifications. These boxes are relatively simple to put together if you have the basic tools required and are clear cut so as not to be confusing how to assemble.
All designs can be found at Skar Audio - Where Audiophiles Meet Excellence > Knowledge Base (Footer Link) as well as in this thread..
We will be coming out with designs like this for all of our different woofer lines specifically for each series, so stay tuned if you have other Skar Audio speakers.
Edited by skaraudio
Skar Audio
www.SkarAudio.com
Phone : (888) 501-7527
waits to see how long the will this design work with xxxxxx woofers too start to come rolling in
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Wow this is a great Idea. Takes the guess work out for you subs.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
  • 1 month later...
  • 4 weeks later...
using torres and inputting the specs on the skar website there is something wrong:
Skar website: Outside Dimensions : 19” Wide x 20” Deep x 14.5” High says gross volume is 2.0 Ft ^3
Torres Calculator: Outside dimensions : 19” Wide x 20” Deep x 14.5” High says gross volume is 2.44 Ft^3
That difference is kind of a big deal especially since the skar site says its tuned at 32hz where as torres says its tuned at 39hz?
I am basically trying to figure out why there is such a big difference as I am trying to design a box for a honda accord, but the information isn't adding up.
  • Who's Online   0 Members, 0 Anonymous, 891 Guests (See full list)
