FrontierGello Posted December 21, 2013 Report Share Posted December 21, 2013 how do you reinforce the roof? is 1/2 mdf enough? bracing it with 1x3 wood? Nissan Frontier 10" Cadence Midbass 8" Cadnece Midrange Bullet tweets 2 Re audio Sxx 15 Subs Mechman 270a 2 Re XT4000deV3 mono 1600 rms 1 Re XT400deV3 Bridged 350x2 2 Cadence 175.4 Bridged 350x2 Audiomaxx and Stinger 0,4,8,12 awg wires Dynamat sound deadeners My Build Log: http://www.stevemead...__+1999 +nissan Link to comment Share on other sites More sharing options...
FrontierGello Posted December 21, 2013 Author Report Share Posted December 21, 2013 here's my roof: Nissan Frontier 10" Cadence Midbass 8" Cadnece Midrange Bullet tweets 2 Re audio Sxx 15 Subs Mechman 270a 2 Re XT4000deV3 mono 1600 rms 1 Re XT400deV3 Bridged 350x2 2 Cadence 175.4 Bridged 350x2 Audiomaxx and Stinger 0,4,8,12 awg wires Dynamat sound deadeners My Build Log: http://www.stevemead...__+1999 +nissan Link to comment Share on other sites More sharing options...
Brandonbkd Posted December 21, 2013 Report Share Posted December 21, 2013 Glue 3/4 on it with PL Premium FI BL18 Build Log: CLICK HERE!! 2003 Explorer Sport: FI BL18 SoundQubed 2200 at 0.7ohm Pioneer DEH-2500UI Pioneer 6 x 8s Rockford Fosgate 6 x 9s 5 ft^3 box at 35hz Lots of Mega Mat Link to comment Share on other sites More sharing options...
Brandonbkd Posted December 21, 2013 Report Share Posted December 21, 2013 If those metal cross braces aren't actually attached to the roof, glueing those will make a huge difference by themselves FI BL18 Build Log: CLICK HERE!! 2003 Explorer Sport: FI BL18 SoundQubed 2200 at 0.7ohm Pioneer DEH-2500UI Pioneer 6 x 8s Rockford Fosgate 6 x 9s 5 ft^3 box at 35hz Lots of Mega Mat Link to comment Share on other sites More sharing options...
tacomaguy1 Posted December 21, 2013 Report Share Posted December 21, 2013 3/4" with pl premium Team Flex Issues Link to comment Share on other sites More sharing options...
SnowDrifter Posted December 21, 2013 Report Share Posted December 21, 2013 Glue the cross braces to the roof with polyurethane adhesive. Give it a looong time to try. 3-4 days. Then deadener Or you can always to an MDF roof ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
DubNDodge Posted December 21, 2013 Report Share Posted December 21, 2013 Attach mdf to roof one way or another. Drill holes through mdf (don't go through roof) , stick straw of great stuff foam in said holes, fill holes until satisfied. Would be solid as could be. I wouldn't try standing on it unless you walled it off or had a stripper pole in it though. edit: depending on how much strength you want. Snows method is great '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult. Link to comment Share on other sites More sharing options...
Swordlordboy1234 Posted December 21, 2013 Report Share Posted December 21, 2013 Insert picture of resin roof. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect? Link to comment Share on other sites More sharing options...
SnowDrifter Posted December 21, 2013 Report Share Posted December 21, 2013 ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
DubNDodge Posted December 21, 2013 Report Share Posted December 21, 2013 Insert picture of resin roof. edit: fuuuuuuuuuuuuuuuuuuuuuuuu. ninja'd. had to go look through my pb lol. I knew I saved it '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult. Link to comment Share on other sites More sharing options...
