WastedTalent Posted January 16, 2014 Report Share Posted January 16, 2014 If you read online about how to see if your battery is bad... they always talk about getting rid of the "resting charge" or some shit... where you turn off your car and leave the headlights on for like 10-15 mins. It takes all the power from the battery that is just resting or something and then when you test it, it's reading what the battery has stored. (don't know all the technical shit, i'm tired, leave me alone. just google "how to test battery to see if it's bad" or something similar). in my mind, I think of it like... filling up a pop at fast food. you pour the pop into the cup (alt/charger charging the batts) and the fizz is that resting charge. well, use the headlights or whatnot for few mins to get rid of the "fizz" and you're left with what the battery actually contains. Again, tired, not sure of all the technical terms, but there ya go Sheena = pedobear Link to comment Share on other sites More sharing options...
momofx76 Posted January 18, 2014 Author Report Share Posted January 18, 2014 LOL yeah I get what you're saying and I think I read that somewhere online too! Yeah I was thinking about taking the Kinetik out and testing it first before taking apart the bank of 6 in the back :/ what fun... Link to comment Share on other sites More sharing options...
SnowDrifter Posted January 18, 2014 Report Share Posted January 18, 2014 What does the voltage drop to with the car off overnight? And I mean OFF OFF. Not just radio-on ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
MECHMAN Posted January 18, 2014 Report Share Posted January 18, 2014 Try putting a GOOD agm style battery charger on them when the vehicle is parked and not in use. With a battery bank that large, they do need to be topped off whenever you have time. If the overall resting voltage does not improve, the batteries might be getting old / sulfated, or you could have a bad one in the bank. Properly charged AGM batteries that are in good condition should rest about 12.9 - 13.1 volts @ 77 degrees F. 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
momofx76 Posted January 19, 2014 Author Report Share Posted January 19, 2014 What does the voltage drop to with the car off overnight? And I mean OFF OFF. Not just radio-on Well I just got back from a 400 mile highway drive so I will check in the morning what it rests at. However, I do have an aftermarket alarm installed and the temp is currently around 25F... Try putting a GOOD agm style battery charger on them when the vehicle is parked and not in use. With a battery bank that large, they do need to be topped off whenever you have time. If the overall resting voltage does not improve, the batteries might be getting old / sulfated, or you could have a bad one in the bank. Properly charged AGM batteries that are in good condition should rest about 12.9 - 13.1 volts @ 77 degrees F. Mechman, do you think the CTEK7002 is not good enough for my battery setup? I did notice that when hook it up to the batteries, it takes about 8 to 10 hours at MOST to shut off and say they are fully charged... Link to comment Share on other sites More sharing options...
momofx76 Posted January 20, 2014 Author Report Share Posted January 20, 2014 It dropped back to 12.5V when I got in it this morning... What does the voltage drop to with the car off overnight? And I mean OFF OFF. Not just radio-on Link to comment Share on other sites More sharing options...
MECHMAN Posted January 21, 2014 Report Share Posted January 21, 2014 It sounds like those batteries might be slightly tired. 12.5 isn't terrible in cold weather, but it's not great either. You might also want to check for parasitic drains on it, lowering the battery voltage overnight. 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
BassMunky Posted January 21, 2014 Report Share Posted January 21, 2014 when you charge them can you charge them all at once with one charger or each battery individually? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted January 22, 2014 Report Share Posted January 22, 2014 help with question? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
momofx76 Posted January 24, 2014 Author Report Share Posted January 24, 2014 when you charge them can you charge them all at once with one charger or each battery individually? Kinda off topic here bro lol but its cool - I was told you suppose to charge them all at once, from the front battery... Link to comment Share on other sites More sharing options...
