Amp Test Tuesday - DC Audio 9.0k @ 16v (limited P.S.) (GUESS the Wattage! WIN STUFF!) RESULTS PAGE 8
68,340 total
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
this should be interesting.. this will be the numbers some might see if they run it on a 12v system.. might even get more out of it with a beefy 12v system..
1. Certified Mode (test stops @ 1% Distortion) @ 1 ohm (7,448watts)
2. Non Certified Mode (test stops at Clipping) @ 1 ohm (8108watts)
3. Non Certified Mode (Test Stops @ Clipping) @ .8ohms (8649 watts)
4. Dynamic RMS Burst Mode (Test stops @ clipping) @ 1 ohm) (8998 watts)
5. Dynamic RMS Burst Mode (Test stops @ clipping) @ .8ohms) (9150watts)
55,495
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   1 Member, 0 Anonymous, 764 Guests (See full list)
