Center console in f250
Thumper350
Here is a design for a ported 10"
Screenshot2014-02-11200422_zps18f3d569.p
Its 1.25 cu ft net, tuned to about 35 hz.
Cutsheet:
Top/Bottom = 20" x 16"
Sides = 20" x 10-1/2"
Baffles = 12-5/16" x 10-1/2"
Back = 14-1/2" x 10-1/2"
Port = 10-1/2 x 16-3/4"
The model shows the driver recessed into the front baffle, whether you want to do that or not is up to you.
Builds:
For an X-10 you will probably want more port area. I can revise the design for more port area, it should work for both the SA-10 and the X-10 then. I can work on it later tonight.
FYI, an X-10 in the same box and on the same amp isn't going to be any louder at all than a SA-10 in the same box and the same amp. What the X-10 will get you is the ability to take a lot more power, that's where your extra volume will come from.
Builds:
  • Who's Online   1 Member, 0 Anonymous, 713 Guests (See full list)
