Running my amp at lower impedance than it's meant for?
chrisw.
Ok so I'm no noob and I know its every rookies mistake to try and push their equipment just past what its recomended. But... I recently had my amp clamp tested by a friend and we dropped it down to 2ohm mono for kicks (only 4Ohm stable) and it belted out just a hair under 1kw! Not bad for an amp that's only rated at 300w rms x 1 lol. I should mention the amp is an old school MTX Thunder amp notoriously known to being underrated and built like tanks.
So channeling the teenager within I've proceded to start running the ampgetting at 2Ohms mono for the last month and it's been awesome! I told myself this is stupid and if it starts to run hotter than normal or goes into thermal protection I'm going to knock it off and go back to running it @ 4ohms. But the thing is it hasn't. It just performs like its meant to be run like that.
-Is this giving me a faulse sense of security?
-If it were under strain would I know it? Would it be obvious?
-Are there amps out there that run lower than recomended all day with no problem?
-If I do fry it by doing this, will it be repairable?
Thanks
Still Living in the 90's
MTX Thunder 2300x
MTX Thunder 2150x
MTX Thunder 275x
MTX Thunder 1500dx <---still searching
I'll be honest with you, I didn't even read your post.
Bottom line is that dropping an amp below it's recommended lowest impedance will generate more heat than it's designed to take and basically self destruct eventually. Self destruct like the last seen in Predator .
So don't do it! The gains in wattage if any aren't worth it.
Remember Predator, ya like that
Rolex you sicken me.
Just let me finish my pie
~ Juice
I hope you keep a fire extinguisher handy ... It's not a matter of if, but a matter of when ...
Just because you see a 55 mph speed limit sign doesn't mean you can drive 75 mph whenever you fell like it ...
... one day when you least expect it ... you will get that speeding ticket ...
Always better to be safe that sorry ...
To answer you questions, if it gets hot thats a sign. If it were to break it would cost more than its worth to fix it.
Its more about are you willing to replace it if it breaks? If its a quality amp, and you can keep the voltage up, then your minimalizing the risk..
If its a good amp, itll go into protect maybe. Then you know. If not then itll shit itself possibly catching on fire.
Your call.
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
Old school amplifiers do not have the "Up to Date" protection circuits like the amplifiers of today ... plainly put, they are not idiot proof ...
Nobody ever said that the amplifiers would not play below rated ... but that they are not made for it and recommends against it ...
Luck probably
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
LMAO Do they actually catch on fire? I thought that was a joke
Well @ 4ohms the amp will run hot and go into protection if I clap it out for too long so I know the protection circuit is doing its job that's why I am more or less judging it by that.
Since it's been at 2ohms I'm carefully with the volume and it hasn't shut itself down even once
As far as replacing it. Yeah I think it time to upgrade to an amp with more power and this amp cost me $40 used so it's not a huge loss other than it being a really nice amp compared to today's amps.
MTX Thunder 2300x
MTX Thunder 2150x
MTX Thunder 275x
Why hasn't it gone into thermal protection though?
The same reason my car doesn't shut down when I go deep into redline.
Cause your brain should kick in well b4 any on board safety circuitry. It sounds like your willingly playing with fire, and that's cool, god knows I've done it. Jut be willing to except the consequences that come with it. I've never burned down a car, but me testing the laws of physics has caused a few fires
~ Juice
  • Who's Online   1 Member, 0 Anonymous, 1579 Guests (See full list)
