X-15 6th order design help
soBASED
^^^Tuning a bandpass box low has NO effect on how low it plays. The size of the sealed chamber affects how low you can play. The ported section affects where you're high end rolloff will occur. Just to clear that up for you OP ;)
Edit-I was referring to the 4th order bandpass
I wouldnt try to tune a 4th low o.O. but im trying to achieve a good response from 25-60 pretty much.. Im willing to pretty much spare my whole trunk for a 6th. If I can design one thatll fit, im doing it. Prob do interchangeable ports if I can. Im gonna change where my ports are and trying to see if I can port each side on each side of the box (left and right) or my rear deck is gonna get in the way. I'll measure my max height tomorrow. Can anyone recommend tuning for each chamber
Car:
- 2013 Honda Accord Sport 6MT
- aFe SRI
Electrical:
- Big 3 w/ Execution Audio 0/1 AWG OFC
- Stock Battery
Audio:
- JBL Power Series 6.5 Comps up front (Running off HU power atm)
- JBL Power Series 2-Ways in the rear deck (Running off HU power atm)
Subwoofer:
- Sundown Audio X-15
- CT Sounds AT1400.1D (@1 ohm)
Bedroom:
- Yamaha RX-V365
- Pair of Klipsch KG4.2's
- 2 E8v3's in a 1.34ft^3 tuned to 30hz
- No Amp yet..
- CoolMax ZU900B PSU for amp
In my room & previous car:
- Amp: Soundstream TX1.1300D @ 4 ohms (520 watts)
- T-Line Enclosure tuned to 32hz
YouTube : http://www.youtube.c...r8?feature=mhee
Okay thanks for the info. I forgot to mention that for the new box, I would be sealing it off. What kind of port per cubic feet would you recommend for the high tuning chamber?] For the low, I would do a slot port and I know id have more than my current setup
Car:
- aFe SRI
Electrical:
- Stock Battery
Audio:
Subwoofer:
Bedroom:
- Yamaha RX-V365
- No Amp yet..
So I measured my trunk again, and because the rear deck comes down near the seat more, the box will have to be behind that (unless sub faces up inside the box, ported on bottom and top) but my dimmensions are 17.75"H x 30.5"W x 30"D. I came up with a design that works (but dont know if its actually good). Chamber 1 is 3.7ft^3 tuned to 28hz.(15.37^2 inches per foot) Chamber 2 is 1.39ft^3 tuned to 74hz.(58.45^2 inches per foot) This is with the low pass set at 80hz and forgot to add the SSF. The sub will be facing one side of the box and ported on each side firing into the cabin, sealed off from the trunk.
Car:
- aFe SRI
Electrical:
- Stock Battery
Audio:
Subwoofer:
Bedroom:
- Yamaha RX-V365
- No Amp yet..
How did you get winISD .50? I have the .44 and that's the only one I found.
i dont exactly know lol... I had downloaded it a long time ago too.. I think I just searched online and found a site to download it from haha
Car:
- aFe SRI
Electrical:
- Stock Battery
Audio:
Subwoofer:
Bedroom:
- Yamaha RX-V365
- No Amp yet..
  • 2 months later...
  • Who's Online   1 Member, 0 Anonymous, 1712 Guests (See full list)
