TeamHT Posted April 9, 2014 Report Share Posted April 9, 2014 The wall does not flex...but the wall is flexing. I'm a little confused... Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
alaskanzx5 Posted April 9, 2014 Report Share Posted April 9, 2014 The baffle is the whole side of the enclosure that the subs are mounted to. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted April 9, 2014 Report Share Posted April 9, 2014 I think he means his box is almost jumping. Did you bolt the box to the body and or frame? Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
ParDeus Posted April 9, 2014 Report Share Posted April 9, 2014 I think he means his box is almost jumping. Box rise! Link to comment Share on other sites More sharing options...
TortoiseShore Posted April 9, 2014 Report Share Posted April 9, 2014 I think he means his beauty panel is flexing on the outer edges. Or at least that's how I understand it Link to comment Share on other sites More sharing options...
TZspeakersZac Posted April 10, 2014 Author Report Share Posted April 10, 2014 Okay maybe this will be more clear.I don't know if the image will show up but this is how my subs are mounted, looking in through the port. It's a 4th. Probably should have made that more clear. This is exactly where it's flexing. On the left of that image is the panel in which I have the port, but it is not flexing. It is just this area. The foam overlaps the MDF a bit by about an inch. There are 2 more sheets behind this one. Before the "lol looks great" I haven't finished making it look all pretty, at least on the outside haha! It's been too cold in Michigan to do any work. Nah man, it's cuz of the bass. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted April 10, 2014 Report Share Posted April 10, 2014 Where in Michigan are you? if its the beauty panel, how is itattsched? t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted April 10, 2014 Report Share Posted April 10, 2014 A pic that shows more of.the whole box would be nice t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
TZspeakersZac Posted April 10, 2014 Author Report Share Posted April 10, 2014 I'll take one later on tomorrow... Didn't think to and it's a bit too late now. I'm in Detroit metro, though I'm currently in Mt. Pleasant for the next 3 weeks or so. I didn't know it was called a beauty panel, I'm just using it to seal the cabin and it's anything but pretty at the moment. It's attached by 2 metal brackets on each side of the enclosure (total of 8 )in addition to a load of PL Premium and expanding foam. There are 3 layers, each is glued to the others with titebond III. Nah man, it's cuz of the bass. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted April 10, 2014 Report Share Posted April 10, 2014 There are members in the Detroit area that could maybe take a look at it in person. Look up the Michigan people thread t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
