njedwardz Posted April 28, 2014 Report Share Posted April 28, 2014 Hey all, I initially posted this on CorvetteForum but thought it would apply here as well. Steve's the one who got me really interested in car audio, so there's not a more fitting place than his forum! Warning: this thread is decently long and picture heavy. Sorry. Just wanted to share a little project I've been working on for a while. Before I even bought my car last July, I knew that no factory stereo system would satisfy me. I'd never done a true full system build, but I'd always wanted to. I knew I'd want sound deadening and noise isolation material throughout the car. I wanted crisp, clear mids and highs that would be loud and distortion free. Without a doubt, I had to have hard-hitting, breathtaking bass. And above all, everything had to look good. With these goals in mind, I embarked on a project that was, in many ways, a learning experience. I used a few threads on this forum for guidelines: http://forums.corvetteforum.com/audio-electronics/2992562-sound-deadening-and-stereo-install-step-by-step.html http://forums.corvetteforum.com/audio-electronics/1471466-c6-vert-amp-and-speaker-installation-write-up.html http://forums.corvetteforum.com/audio-electronics/1936113-add-gm24-pinout.html http://www.lazyassgeek.com/c6-stereo-information/how-to-create-an-rca-output-using-pac-add-gm24/ I also used countless other resources that I've forgotten to record. If I have time to locate them I will edit this post with them. Before I get into the goods, here's the specs of the system (I'll also list forum vendors if applicable): From Double D Mods: Pioneer AVIC-8000NEX GMOS-04 integration module Maestro SW steering wheel retention module Pioneer ND-BC20PA backup camera custom pre-wiring of all connections dash bezel, antenna adapter, etc. From VetteNuts: 2x JL Audio 10W3v3-4 subwoofers Driver and Passenger subwoofer boxes custom VetteBin style amp rack Sourced elsewhere: Rockford Fosgate 3Sixty.3 processor/eq/ta RF T400-4 mid/high amplifier RF T1000-1bdCP subwoofer amplifier RF T3652-S 6.5" woofers/1" tweeters (front doors) (mounted in speaker baffles from a non-forum vendor) RF T152 5.25" coaxial speakers (rear fill) Sky High Car Audio 1/0, 4, 14 ga power wire (all OFC) SHCA 14ga speaker wire (OFC) SHCA wire heatshrinks SHCA 1/0 full copper lugs Techflex sleeving KnuKonceptz main fuse and distribution blocks Second Skin Audio Damplifier Pro and Luxury Liner Pro sound deadening/noise isolation Stinger 8000 series RCA interconnects XS Power D3400 AGM battery XS Power iBar multiple terminal kit Now that that's through... I started all this in October, when I decided to upgrade my battery and charging cable. October 24: I went with an XS Power D3400 battery mostly because of a guy named Steve Meade. If you haven't heard of him, https://www.youtube.com/user/meade916. The ability to add an extra set of terminals to these batteries is really neat, as I wanted to retain my factory wiring ends as well as add a few accessories.... October 25: Here's a view of the battery installed in the car. I ended up installing it rotated 180 degrees from the factory direction due to factory cable lengths and terminal orientation. You can also see the extra terminals and wing nuts. A couple weeks later, I added a custom big 3 kit to the car, complete with Sky High Car Audio 1/0 AWG pure OFC cable, an SHCA AGM fuse holder, Techflex sleeving, SHCA heatshrink ends, and SHCA 1/0 pure copper ring terminals. October 23: View of the unsleeved SHCA cable, fuse holder, terminal, heat shrink, and a quarter for size comparison. I decided to tin the SHCA ring terminals for optimal corrosion resistance. Here's a before/after view. They're not as pretty, but they may last longer. October 23: The terminals were affixed to the wire with solder - first they were completely filled with molten solder, then the wire was inserted and allowed to cool. I don't have any photos of this process - sorry. November 7: Detail view of the SHCA wiring with sleeving/heatshrink/tinned terminals. The long run of positive cable has additional heat shielding that I picked up at a local auto parts supply store. Don't recall the brand. Needed this due to close proximity to engine components. November 7: Here are some views of the big 3 installed. Clockwise from top left: +12V from alternator (factory wire still connected), +12V to battery from alternator, ground connection to engine block, SHCA fuse block (between alternator and battery, mounted to fender well next to fuse box). Not shown is the ground connection that was added to an existing frame ground. I scuffed off some of the paint around the connection. Again, factory wiring at this point was left intact. I based my big 3 install off of a guide I found somewhere on here. I apologize, I seem to have lost the link for it. The car remained in this condition for a little less than 2 months while I planned and ordered the rest of the build. Toward the end of December, I had ordered everything, and had received most of the components, with the exception of the head unit which I knew would be delayed until Aprilish. Dennis at Double D was a pleasure to deal with RE: the head unit. I was also waiting on an amp rack, subs, and sub boxes from a non-forum vendor, but I figured that they would arrive before I was done with everything anyway. From here on out, the dates probably aren't accurate, but I don't feel like going to my camera to find the exact ones. These are the dates from when they were uploaded to my facebook. December 4: RF T400-4 amplifier. This will run the front/rear mids/highs. December 5: RF T1000-1bdCP amplifier. This will run the subwoofers. Physically identical to the above amp as far as dimensions are concerned, which made amp rack design rather simple. December 5: A shot of me testing out the RF T1000-1bdCP on my portable sound system. Normally, none of these wires would be visible, but this was my only real setup to test this out. December 5: amplifier boxes. December 12: RF 3Sixty.3 processor arrives. December 12: I seem to have ordered way too much polyfill... also the box for the 3Sixty.3 atop the amp boxes December 16: making sure the 3Sixty.3 powers up and connects to my laptop properly. Please excuse the background.....my workbench has multiple purposes, it seems. December 19: care package from Sky High Car Audio arrives. December 20: RF T3652-S woofers/tweeters arrive. Packaging is exquisite. December 20: The guest bedroom is dubbed "The S**T Room" by my father. Link to comment Share on other sites More sharing options...
njedwardz Posted April 28, 2014 Author Report Share Posted April 28, 2014 December 28: view of new KnuKnoceptz main fuse blocks. The SHCA blocks were too large to fit two of them, so I decided to use two of the Knu blocks. December 29: I started by pulling the car into the garage at an angle so that I could get the passenger seat out more easily. I had initially thought about turning the car 90 degrees with dollies, but that proved to be unnecessary. December 30: seats out December 30: front carpet, center console, dash bezel removed December 30: another view of the last picture December 30: For whatever reason, I didn't take any photos of the sound deadening process. It was rather boring, and really doesn't look all that different from stock. Sorry. January 10: view of the mess that my garage had become at this point. much of it is trash from the sound deadening material's wax paper backing. January 13: view of 3sixty.3 remote location January 14: view of prototype locations/installations of primary power distribution block, secondary power and ground distribution, and primary ground distribution block. This is not the current configuration of the car, as you will see later. January 14: view of the Rockford Fosgate 3Sixty.3 installed in its prototype location in the rear driver fender well. Ugly, but would be covered by carpet. This is not the current configuration. January 14: Another view of new KnuKnoceptz main fuse blocks. The SHCA blocks were too large to fit two of them, so I decided to use two of the Knu blocks. Here you can also see the amount of wiring added to the engine bay. Excuse the torn sleeving; this has since been remedied. January 14: Another view of above. Door and rear fill speakers were also installed at this point. No clue why I don't have pictures of that; mostly uneventful but still would've been nice to look at. Sorry. At this point, I replaced front carpeting, seats, factory head unit, etc. All I was waiting on to fully assemble the car was the sub boxes, subs, and amp rack. The head unit and related accessories could go in whenever Pioneer shipped the new models out. Up until this point, I had been borrowing my uncle's truck for transportation. University was out of session for the winter, so I didn't have to worry about being anywhere. Dad's Stingray was in the shop for some collision repair (went into the shop before I started and didn't get out until last month...) so I couldn't drive his rental. I drove around for a couple weeks with no radio, which sucked, but it gave me time to analyze the sound of my car's headers through the stock mufflers with the added sound deadening. I had a set of B&B PRT mufflers installed because of these 2 weeks. Just wasn't loud enough! January 23: My grandfather was in the hospital out of town toward the end of January, and I realllly needed a stereo to make the 3 hour drive across the state. As my stuff was nowhere to be found, I resorted to this: The car literally remained in this exact condition for almost 3 months. About 2 months in, I grew tired of the constant excuses and decided to cut my losses and pursue other options for sub boxes and an amp rack. I contacted Marc at VetteNuts and started throwing ideas around with him. I scrapped my initial idea of an amp rack between the two sub boxes and settled on a rack that would go behind the seats, like a VetteBin. Literally less than 2 weeks after ordering from Marc, he had the products at my front door. THAT is customer service! Not sure why I don't have any out-of-car photos of the amp rack. Sorry. April 16: head unit and accessories arrive from Dennis at Double D Mods. Again, great customer service. Could've sworn I took some pictures of me mocking things up inside the amp rack but I couldn't find any. sorry. April 18: rear carpet re-installed. Amp rack base installed in car - components installed on base with t-nuts (amps, processor) and wood screws (power distribution/relay circuitry). wiring is a mess but it gets better. April 18: sub boxes/subs temporarily installed for wire length check. April 18: another view of the amp rack, after a little wire management Link to comment Share on other sites More sharing options...
njedwardz Posted April 28, 2014 Author Report Share Posted April 28, 2014 April 18: close up of low-amperage power distribution/relay circuitry I'll break this down: power and ground connections come from primary distribution blocks (in passenger rear fender well behind carpet) and connect on the right side of image. from here, power is split to 4 fused channels (grey fuse block in middle of image). 2 are unused. One channel feeds the 3Sixty.3, which needs a constant power source and is switched on by the head unit's accessory signal. The other channel feeds the relay. when the head unit is on, the 3Sixty.3 energizes the relay, which sends power to 6 fused channels (2x amp turn ons, backup camera power, amp rack cooling fan, 2 spare) [black fuse block on left] April 19: close up of sleeved/heatshrunk ends of SHCA 4ga OFC power cable entering RF T1000-1bdCP amplifier. April 19: more wire management completed April 19: a view of the kitchen table. Helmet's from the race track (was there the morning of the 18th to drive a Mustang FR500S, which was incredible). Sub boxes and subs are visible at lower right, amp rack is visible at far left (barely) April 19: ran out of room everywhere else so I had to use the kitchen counter to mount the amps to the amp rack and run low-amperage wires for turn-ons, etc. April 19: another view of "The S**T Room" (it still looks like this; I'll probably get to it next weekend) April 19: garage is finally getting a little better now that most of the car is in the car April 19: view of head unit installation. In a rush because I'm supposed to have Easter lunch 150 miles away less than 13 hours from when this photo was taken. Ended up not sleeping. April 20: view of installed head unit. Looks incredible. Noticed problem with speed sense wire (says I'm doing 66 while stopped in my driveway). Fixed issue later in the week. Insert family Easter lunch. Insert impromptu visit to beach house in Pensacola, FL. Insert even more impromptu spring break shenanigans in Destin, FL. Insert pissed off 3 AM drive back to LA because of other stupid college kids, complete with awesome full throttle pull through the Mobile tunnel (boy that was loud). April 24: back home, rear wall carpet installed. April 24: view of amp rack with cover in place. hidden fan located on passenger side. Project "complete" (because nothing's ever really done when you start modding things...) I haven't done any equilization or time alignment yet; I'll probably wait until exams are concluded. As it is, the system sounds incredible. There are a couple places that I'll be adding additional sound deadening to this summer. So, what do y'all think? Leave a comment, criticism, etc. Thanks for stopping by!!!\ NJE Link to comment Share on other sites More sharing options...
Smoove Posted April 28, 2014 Report Share Posted April 28, 2014 First : My wife would kill me if I had project scatted around the house like thatSecond : Nice choice in gear. third : Nice choice for a ride Forth : came out nice an clean as it should in that car.How does it sound? 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
goodvibez Posted April 28, 2014 Report Share Posted April 28, 2014 I think you did a kick ass job! Good gear in a great ride! Very clean and tidy, well planned out! Funny how the people who have a louder system than you will usually give you a compliment about your setup because they know how much blood, sweat, time, and money you put into it. The people who criticize or try and one up you....have a p.o.s to no system at all and will tell you all about this "other" guys system! Saddley I'm sure if I meet this "other" guy...he will probably tell me he thinks your just as annoying as I think you are! I'm not compensating, just proud of fabricating! My build log: 10k center console with 4 DC Audio XL 10's powered by 2 DC Audio 5.0k amps 5 xs batteries and dual DC Power 300xps alts http://www.stevemeadedesigns.com/board/topic/169404-goodvibez-04-dmax-10k-center-console-w4-xl-10s-custom-5ksit-plays/page-19 Link to comment Share on other sites More sharing options...
audiofanaticz Posted April 28, 2014 Report Share Posted April 28, 2014 I smell something fishy Link to comment Share on other sites More sharing options...
Tecomah Posted April 28, 2014 Report Share Posted April 28, 2014 Looks really clean 750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.^ DON'T BE A DICK LIKE THIS GUY Team Subsonic Lows Link to comment Share on other sites More sharing options...
njedwardz Posted April 28, 2014 Author Report Share Posted April 28, 2014 I smell something fishy Care to elaborate? Smells a bit like fiberglass, MDF, and fresh carpet to me. First : My wife would kill me if I had project scatted around the house like that Second : Nice choice in gear. third : Nice choice for a ride Forth : came out nice an clean as it should in that car. How does it sound? Sounds excellent. Crisp and clean highs, incredible (by my standards) bass. Max clean volume on HU is 33 (according to DD-1+), pre-outs of 3Sixty.3 turned down to around 3.8 vRMS, gains set with -3 overlap on subs and -5 on mids/highs (sub amp is ~500 over rated for the subs, according to the RF PVC), and I haven't turned the volume above 22 yet, and it's been superbly impressive. I have yet to do any EQ or TA on the car; I have a feeling it needs quite a bit of both to get the sound "perfect". After the semester's over I'll be doing some experimenting with an RTA/FFT's and some pink noise. The car isn't any noticeably slower than it was before, although I expected at least a little impact from adding ~200lbs of weight to the entire car. Balance is probably about equal due to the battery in the front and subs/amps in the back. I'll cut the speed/handling difference with new tires, shocks, and probably a head/cam package this summer or fall. Thanks for stopping by!! Link to comment Share on other sites More sharing options...
FieroGrande Posted April 28, 2014 Report Share Posted April 28, 2014 Love the ride. I hope to one day get a vette. Keep the pics rolling in Link to comment Share on other sites More sharing options...
OrionStang Posted April 28, 2014 Report Share Posted April 28, 2014 I smell something fishy Bass? LOL Haha, but really what you thinking Brian? SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
