Alright guys I'm finally starting to work on the Tahoe and figured I'd post all of what I'm putting in it and keep everyone updated with the Build Progress.
SYSTEM:
- 1 Fi Team15 (Dual 2 Ohm)
- BOX: will be designed by RamDesigns (blueprints), not sure the specifics yet. Most likely 7-8 Gross Cu.Ft. for a single 15.
- AQ 3500.D Amp (4300 Watt RMS @1ohm, may be wired to .75 ohm sooo more watts?)
- Pair of AQ Pro Audio 6.5's
- Pair of AQ Supertweeters
- AQ 4-120 Amp
- VooDoo 0-Gauge Wire (50ft Red / 50ft Blue)
- SMD DD1 Distortion/Gain Indicator
- Second Skin Alpha Damp
- Second Skin Damplifier Pro B-Stock
- Second Skin Luxury Liner Pro
- 1 XS D3400 (in front)
- 2 XS D3100's (in rear)
  • Replies 24
  • Created
  • Last Reply
Please do not wire that amp below .75 and fry the leads on the sub. And how do you plan to wire a dual 2 to .75? single dual 2 you get 1ohm or 4ohm. 7-8 cubes on that 15 is not necessary. 7-8 cubes is more for an 18
Ok well it IS a Dual 2 Ohm sub but on Fi's site they label it "1.49 ohms" as 2-ohm thats why i figured .75. I would like 1 ohm final impedence though. And, with the box i'm doing 4-5 net cubic feet, but 7+ gross cu ft. Check "Altima1" on here his box slams the lows which is just what im after
4-5 net is good. Ram-designs is a good way to go. He will get you setup with a good box.
So here is Fi's explanation for the ohm load your seeing
Tuned in, lets get some pics. up, lol
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Tuned in. Now get this system built. it should pound.
  • Who's Online   0 Members, 0 Anonymous, 200 Guests (See full list)
