Daniel Francis Sheppard Posted June 18, 2014 Report Share Posted June 18, 2014 ..... Link to comment Share on other sites More sharing options...
JakeBoucher Posted June 23, 2014 Report Share Posted June 23, 2014 I think everyone needs a little more info to help out? "Dude the more your sub weighs the more watts it puts out" Link to comment Share on other sites More sharing options...
SlamminBeats Posted June 23, 2014 Report Share Posted June 23, 2014 Mike bates --> Blake Farrar --> This guy Link to comment Share on other sites More sharing options...
Daniel Francis Sheppard Posted June 23, 2014 Author Report Share Posted June 23, 2014 the problem resolved itself... when my remote wire came kinked behind the headunit the amps lost power. after i fixed the remote wire the speakers played static for a little bit but i couldnt figure out why. after about a day the static stopped. i believe this was caused by the amps needing to build themselves back up after draining because the static disappered over time. Link to comment Share on other sites More sharing options...
Bump4life Posted June 23, 2014 Report Share Posted June 23, 2014 Mike bates --> Blake Farrar --> This guy LOL. mikey bates. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
Daniel Francis Sheppard Posted June 23, 2014 Author Report Share Posted June 23, 2014 i put those dots because i wanted to delete the post but I dont know how to or know if you can... Link to comment Share on other sites More sharing options...
SlamminBeats Posted June 23, 2014 Report Share Posted June 23, 2014 i put those dots because i wanted to delete the post but I dont know how to or know if you can... good deal man, havent i seen this post like twice before? maybe im losing it. Link to comment Share on other sites More sharing options...
Kranny Posted June 23, 2014 Report Share Posted June 23, 2014 the problem resolved itself... when my remote wire came kinked behind the headunit the amps lost power. after i fixed the remote wire the speakers played static for a little bit but i couldnt figure out why. after about a day the static stopped. i believe this was caused by the amps needing to build themselves back up after draining because the static disappered over time. that makes no sense whatsoever. if the amps are turned on, then they are fully powered up. there is no "burn-in" time for amps that have not been turned on for a while. Link to comment Share on other sites More sharing options...
SlamminBeats Posted June 23, 2014 Report Share Posted June 23, 2014 the problem resolved itself... when my remote wire came kinked behind the headunit the amps lost power. after i fixed the remote wire the speakers played static for a little bit but i couldnt figure out why. after about a day the static stopped. i believe this was caused by the amps needing to build themselves back up after draining because the static disappered over time. that makes no sense whatsoever. if the amps are turned on, then they are fully powered up. there is no "burn-in" time for amps that have not been turned on for a while. i am just on the floor dead. MY body will be carried out of work today. LMMFAO Link to comment Share on other sites More sharing options...
Daniel Francis Sheppard Posted June 23, 2014 Author Report Share Posted June 23, 2014 the problem resolved itself... when my remote wire came kinked behind the headunit the amps lost power. after i fixed the remote wire the speakers played static for a little bit but i couldnt figure out why. after about a day the static stopped. i believe this was caused by the amps needing to build themselves back up after draining because the static disappered over time. that makes no sense whatsoever. if the amps are turned on, then they are fully powered up. there is no "burn-in" time for amps that have not been turned on for a while. i am just on the floor dead. MY body will be carried out of work today. LMMFAO that is the assumption i made because the problem fixed itself after i made that change. I was finding the undistorted volume for my headunit. when i pulled my headunit out and pushed it back in a kinked the remote wire and the power was lost. So i fixed the remote wire. After fixing the remote wire the left rear wouldnt play and the two front speakers played static on bass notes or low volume. After about a day and installing some second skin in my trunk all the speaker issues dissolved on there own. The left rear starting playing again and the front speakers stopped the static. Idk what happen. Link to comment Share on other sites More sharing options...
