Question about Sundown recommended box specs - E8V3 (2)
So I downloaded Sketchup and pulled up the spec and cut sheet for the E8 dual box.
I need my box to be maybe 4 or 5 inches shorter height wise. Can I take out 5 inches from the height and just add that back in to the length of the box.
Will this mess up the port lengths and change where the box is tuned?
I have plenty room width and length wise it's just the height that is too much.
Here is a screen capture of the box I want to run...
Here is what I am running now.
for your questions none of what you mentioned would work. just out up a thread in the enclosures section, put up your max demenstions and I am sure some one would be nice enough to make you a design
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
I am not sure what's up with these sketchup diagrams on Sundown's site. It's the same cutout sheet for the E8, SD-2 8 and the SA8. Maybe these diagrams are just giving a general idea but i am sure they each require different specs to run effectively.
I built my first box (first one ever) a few weeks ago for a couple of SD-2 8's i have on order and I just used a combo of youtube, forum posts and torres. There's alot of info out there for box building...even for specific drivers like the E8's.
Murdoc
06 civic sedan
alpine cde-hd149bt
sundown sax 150.4
sundown 6.5cs
sundown sd-2 8v2 (pair in a sealed box)
  • Who's Online   1 Member, 0 Anonymous, 1506 Guests (See full list)
